Does CL600 17" fit W210?
Old May 2, 2006 | 10:54 AM
djantlive's Avatar
I am thinking of getting some take off wheels for my W210. These 17x7.5 polished wheels came off of 2002 CL 600. Tires are 225 55 17. Do you think they fit my W210??
Old May 2, 2006 | 11:50 AM
Kar don's Avatar
Mercedes-Benz
different boltsize thats for sure. I wouldn't get em.
Old May 2, 2006 | 03:02 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
The different bolt size is the least of your worries. That can be corrected with custom bolts. The offset on those wheels is way off for the W210.
The W210 can interchange wheels with the CLK, C, and SLK.
W211 E wheels fit, but will require custom bolts.
CL, S and SL won't fit (bolt size AND offset doesn't fit).
Old May 2, 2006 | 11:55 PM
raymond g-'s Avatar
99 E320
If they're simply needing the shorter bolt, 14mm ball...but still fit your 12mm
diameter threading, you no longer need to go custom. Production run of these
are now available from Otisincla.com for about $3 each
....but if the offset is whacked, then even these bolts aren't going to make
it any better.
Old May 3, 2006 | 12:16 AM
djantlive's Avatar
Thx for all the help guys. Sux to pass on a great deal.
Old May 3, 2006 | 02:52 AM
patrick_y's Avatar
2006 E55 and 2002 E320
Those pictures of those wheels have been all over craigslist. I'd make sure that they actually exist prior to getting them.
