check engine light,hesitation
Old May 2, 2006 | 10:48 PM
Gomez153's Avatar
97 e320
i turned my car on and the check engine light came on and when i hit the gas it hesitates real bad.. i just changed the plugs and wires last wk i dont know what it is now it has 92,000 and a maf about 2000 miles ago.....man my first benz and so far a nightmareeeeeee..
Old May 3, 2006 | 02:04 PM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
Check your previous work to make sure everything is hooked up right. That sounds like you have a large intake leak. Make sure that the filter box and MAF connections are solid and sealed.
Old May 3, 2006 | 03:18 PM
E320Star's Avatar
2000 E320 Sedan
O2 sensor. If can sound from under the car, then CAT problem
Old May 3, 2006 | 10:36 PM
Gomez153's Avatar
97 e320
how much is an o2 sensor? and is it easy to install?
Old May 4, 2006 | 08:58 AM
E320Star's Avatar
2000 E320 Sedan
Not sure, usually they cost between 80 to $120 installed at a certified mechanic. I suggest u have it checked before u repair anything
