Euro Front Bumper
Old Jun 9, 2006 | 12:16 AM
risque1's Avatar
99 E320 wagon, 87 560sl.
Question Bumper Impact Molding Lights
I have a euro front bumper and bumper impact molding doesnt have cutouts for the side marker lights. So I was wondering what to do with the light sockets so I dont get a message and or could I still use them?
Old Jun 11, 2006 | 12:05 PM
E-Klasse's Avatar
W205 C300
Put resistors in the sockets to make a load or keep bulbs in and use them elsewhere.
Old Jun 11, 2006 | 05:35 PM
The Godfather's Avatar
4 wheeled car.
easier said than done :P How is it done properly? what type of resistor, and how does it get in the socket?
Old Jun 11, 2006 | 06:50 PM
E-Klasse's Avatar
W205 C300
1) Ohm's Law; The mathematical relationship between voltage, amperage, and resistance. The voltage is 12v, you can get the amps by reading what the wattage of the bulb. Calculate the resistance. The current is equal to the voltage divided by the resistance. Watts equal to the voltage multiplied by the current.
2) With the bulb in, measure the amps in the circuit and calculate the resistance.
3) With a meter, measure the resistance of the bulb.
Resistors have metal leads that you can bend over and stick in the socket.
Old Jun 12, 2006 | 08:49 AM
4 wheeled car.
alright too complicated. no_clue, come here and help me
Old Jun 12, 2006 | 09:40 AM
no_clue's Avatar
.... nothing to brag about, it is a previous model....
sir, yes sir!
Side marker also using 5W bulb, hence our all time favorite 100 ohm 10W radioshack resistor will work perfectly. (enough resistance to "fool" the w210)
http://www.radioshack.com/product/in...entPage=search
Old Jun 15, 2006 | 09:42 AM
4 wheeled car.
Originally Posted by no_clue
sir, yes sir!
SWEET! But how do I plug it in? Just cut the socket and go directly onto the wires?
Old Jun 15, 2006 | 02:25 PM
Whitey's Avatar
98 W210 Advantgarde
sir, yes sir!
Are you sure no_clue? When my LEDs burn out on the licence plates I still get a light out warning (which is of course handy in my case)...in the absence of doing any calculations, I think he might need to try 50 Ohms or lower.
Old Jun 15, 2006 | 02:28 PM
Whitey's Avatar
98 W210 Advantgarde
Mike, one way is be to solder some wires at the ends of the resistors and tie them to the wires connecting to the socket (might as well cut out the entire socket for a cleaner job). However, as I have pointed out, the spec of that resistor may not be enough to fool the computer if you don't have a bulb sitting in there to increase the load. Also make sure u secure the resistor to something that won't melt as the heat generated by it might be quite high - use some 3M doublesided tape and stick it to a metal panel inside the bumper, if you can.
Old Jun 15, 2006 | 03:29 PM
no_clue's Avatar
Your LED bulb burn out? Must be 8-LED/ 9-LED festoon.
I have burnout "4 LED" inside the "8-LED festoon".
I found those 8-LED festoon not very reliable.
Take a good look inside the 8-LED bulb ( no resistor ), so my theory is that...if it is 8-LED, it must using parallel connection within the bulb. It will NOT be possible to light up 8LED serial connected w/ 12V spec.
Say, your car provide 12V, yet it frautuate between 11V to 18V.
3mm LED usually Max out at 3.3V and reach max brightness around 2.7V Such 4X3.3V =13.2V (MAX)
However, if the voltage frautuate in your car may cause excessive current to pass the LED without "resistor to protect them" that caused burn out.
On the 6 LED festoon, serial connection is possible.
at 6X3.3v=19.8V(Max) so...even the car provide only constant 12V, these 6-LED bulb able to reach its 80% brightness.
And the 100 ohm resistant we connected via parallel style really has NOTHING to do w/ the function has the LED bulb w/ put in.
Old Jun 15, 2006 | 03:51 PM
Whitey's Avatar
98 W210 Advantgarde
I think you have explained why mine has been burining out...yes, mostly 4 out of the 8 LEDs burnout, in one case all except one burnt out And the burnouts occur mostly on one particular side. For a moment I thought my car was putting out irregular and sometimes excessive currents, from what you say that is normal a normal thing? I have burnt out 6 bulbs since I embarked on the experiment...
I have been told my latest 8-LED bulbs are "improved" and bighter versions - which seem to be the case. Haven't burnt anyout so far...touch wood! And they do seem a little brighter than the old ones.
So, what do you think? A lower Ohmmage resistor is required to fool the computer where a bulb is not in place?
Perhaps you might want to experiment with your licence plate bulbs..if you take out one of the bulbs, does your bulb-out warning pop up on your dash? In the case of the licence bulbs, I think it is good that my car will still tell me the LEDs have burntout...I hope not too often...
