Signal rear views on 97 E420
Does anyone know if you can put the signal rear view mirrors from the later model E class on a 97 E420? Is there a big issue with wiring the mirrors to the signal markers? Any help would be appreaciated.
Former Vendor of MBWorld
some slow@$$diesels
No problem at all...you need to get complete newstyle mirrors (the blinking housing only doesn't fit on the oldstyle mirror consoles/glasses). The connectors at the blinking mirrors are different and need to be changed to fit the pre updated 210s (or 202s)...after that you only need to run 2 wires per side to properly ground and power the actual blinkers (power can be taken from the connector that goes to the steering column switch/blinkers).
I have several sets of OEM W210 blinking mirrors, but as far as I know, US W210s all have memory driver seats and I don't have a blinking mirrorset with memory motors.
greetingz,
greetingz,
