Rear AC problem?
The car will get cool enough by itself, but I would think that the rear vents should blow hard as well. Any thoughts or suggestions?
Not sure if this has any impact, check the air flow control within the center arm rest (the beer cooler compartment) and see if closing that helps.
How do you get to the the hoses/vents that blow the air in the rear?
Thats because the air is drawn through the filter BEFORE the Blower
Then to the vents....
