Tire Size Help
Front ASA ST4's 18* 8 Goodyear F1GSD3 235/40 R18
Rear ASA ST4's 18* 9 Goodyear F1GSD3 265/35 R18
I want to go 245/40-18 up Front, would there be any difference in ride and would they fit or rub?
I'm planning to go with the Michelin Pilot Sport PS2's
Thanks.
Here is my offset for th efront wheels:
ASA ST4 18*8 offset +37mm
Will the 245/40-18 fit with no issues?
Thanks again.
1) Yes, AMG's have their fenders rolled at the factory so can accomodate wider wheels
2) Unless you're a 430 or a real AMG (I see your's is a 240), the smaller power of the stock car doesn't need the larger tires and will merely slow you down, not to mention worsten the fuel economy a lot.
2) It's ok, I'm not too concerned with losing power since there isn't much you can do with a 240 as far as the motor is concerned. It's a slow car and I can't help it. Though fuel economy is another issue. Thanks.
compresses the front suspension. the inside of the tire will impact the upper
control arm's infamous lug/nut.
to see this nut, turn to full lock. go to the tire which is c ockeded to the outside.
now look at TDC of the tire and the a few inches above. see that little nipple?
that will contact the edge of the tire if sized 245 under certain conditions. in
my case, it's been 2x in 4 months so i just avoid big dips in the road. i have
#3 pads and stock springs/shocks.
i'll just buy 235s when it's time for new tires. may be going with coilovers so
that the rubbing wont occur....plus, the coilovers can also be readjusted lower
and damping adjusted when i lower the car after i get new tires. but for now,
to avoid more rubbing, i'll increase the compression damping of the shock and
no lowering.
Where are you located btw?
For starters, call this company and ask for a Sprintbooster...it will transform your car drastically.
CHUAN KUO TRADING CO LTD
TEL: (886) 2 25959852
Sorry for hijacking your thread Sheldon
