Early W210 Blower Motor Regulator Replacement DIY Here...
2 weeks ago the Benzworld sticky on the window regulator saved my ***, now this one did. $175 and an hour of my time and I have the arctic air blasting once again!
Zack
I've attached 2 photos just in case there is something wrong with the installation. I would much appreciate any insite as what I can do to fix this. I am tired of mechanics and after seeing how easy it was to replace a MAF I am ready to do most of my own work on my 210.
thanks !
Jason
. If you look at my pictures at the beginning of the thread, you will see that all the splicing is done near the regulator itself and the car's wiring harness is left intact. I don't know if this is what's actually the cause of your problem, but I suspect it is.
. If you look at my pictures at the beginning of the thread, you will see that all the splicing is done near the regulator itself and the car's wiring harness is left intact. I don't know if this is what's actually the cause of your problem, but I suspect it is.Jason
I'll start looking for good prices on buying the updated setup. This is gonna hurt.
The hardest part was getting my old body upside down to get to the screws, but other than that, it was a breeze.
THANK YOU SO MUCH FOR SAVING ME HUNDREDS OF DOLLARS AND GIVING ME A/C AGAIN.
Texas gets hot!
thanks !
Jason
What i see from your picture is that your regulator is the original W210 old style one & not W140 one mentioned here.
Most likely your regulator is bad...
If anyone has any suggestions that will save me some $$. I would love to hear them. I would like to do this myself....
thanks,
Jason
thanks,
Jason
Good luck!
My fan motor had completely stopped blowing after slowing a bit and never reaching full blast. To troubleshoot the problem I removed the blue wire going to the fan motor as instructed and jumped the connector it to the body of the fan motor. It roared right up. This was the sign the the fuses and motor all were fine, just the regulator was shot. Rewired the cable, just three solder connections and bam! I am up and running.
You guys are all so great and generous with information. Thanks for sharing the knowledge.
http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW
Now I need to figure out what to do next...ah yes..
Squeaky sound coming from drivers side window, and the passenger side lower seat control moves only moves the seat forward no matter if you push the button toward or away. (Thank god for memory location 1 still moving the seat back)... anyways now what I am talking about?
as per the DIY. It worked great for a while, but, unfortunately
after 6 months, there was a burning smell when the heater was on.
Turns out that one pin in the 4-pin connector and the black wire burnt out.
The connector and wire are part of the regulator kit and DIY instructions
(purchased through ebay).
Perhaps it some fault of mine. I used screw type
connectors and electrical tape instead of solder.
BTW Tony was a fantastic help.
So any help now would be appreciated.
Car history and details
My car is a 1997 Mercedes E-320. Blower would not work. In 2007 summer
replaced regulator, regulator connector and wires as per DIY. Worked
great for 6 months and then poof ... burnt connector. Note the
car side white harness is still the original.
only moves forward ... I rely on the memory. A workaround is, if you
put slight pressure and manually attemt to move the seat in the
direction you intend to WHILE holding down the control (also in the
direction you intend to) ... it co-operates. I gently apply pressure
and "coax" it. Hope that helps
that I thinked MB was just so automatic that blower not needed run higher than lowest... I bought my part from ebay german made for less than 100 installed it in under 1 hour and wooooow now it blows like grazy.
I love this message board I have got help here many times.
jarvisto2
