----99-02 rear brake light----
now how do i install the brake light, i'm upgrading to the thin longer one......
there were directions online here somewhere, no?
the trunk lid side....over to matching horizontals on both pieces, yes, there
are many posts and pics archived in this forum.
basically, you only have to mod the lens which mounts to the trunk lid side.
you take a dremel sanding drum...or wide pencil tip and you carefully layer off
portions of the back side of the reflector which hits the metal work. after about
10 mins tops of this....trial and error....it will seat inside the recessed area w/o
getting all cokceyed. sand...fit...sand some more...fit...etc. DO NOT SAND
through the plastic and into the polished, reflector side!! it's kinda thin. so
just lightly shave....then insert into truck recess....repeat until done.
it'll all become apparent once you position the new piece into your trunk lid and
see where the high spot is on the plastic.
Emily Latella
ALSO, if you OR anyone can give me info about the "FREE ONLINE HARD DRIVE" that you used to have on your signature...I am very interested in acquiring an online hard drive.
cheers!!
cheers!!
concerning the online hard drive....I thot it was you, I guess not.
I've been MIA on the site lately....got busy with my bizness.
About the installation, you don't need any special tool. You need to remove the plastic tack on, just pliers will do that...you might have to replace some of them.
**Very Important...remember to use windex to clean extra black glue(tar) left by the ugly cube-like 3rd brake light. (I 4got to do so, and have to go thru the head ache of removing those damn head ishh
