front suspension
Old Aug 14, 2006 | 04:36 PM
oldwheels's Avatar
99300td
front suspension
Lust had my 99 300td inspected and failed. CAr has 96k on it. They said the following was worn.
R Lwr ball joint
R outer tie rod end
l inner tie rod end.
I havn't jacked the car up yet to inspect.
Is this fairly common, should I replace more than the worn parts.
Is this a bad job to do and will I need special tools??
I searched the treads and get conflicting info as the ball joints pictured on the threads don't look like the ones I see pictured here.
Any info would be appreciated.
