Can i do a peel out in a e320?
Old Aug 21, 2006 | 11:34 PM
LilFazzl's Avatar
Hey. I have a 2000 E320 Stock but is it possible to peel out with it w/o using the e-brake? Also, is it better to drive in mode 4 (sport i think) etc and the asb n stuff. im new to the car.. thanks
Old Aug 22, 2006 | 03:39 AM
ReZzZ320's Avatar
not a really good idea to do a peelout on an E320 since the traction can't be switched on and that might affect the brakes as well
but if you really do manage to pull it off share the videos with us
Old Aug 22, 2006 | 10:21 AM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
I'd like to see you try to peel out with the e-brake on.
Old Aug 22, 2006 | 10:47 AM
Huachipato's Avatar
'04 Cobra & '04 S430
LOL
You would have to hit the brakes and put just enough pressure to lock the front wheels. E-brake is for the back wheels, and being a rear wheel drive, it would very difficult (if not impossilble) to do it with the E-brake.
Old Aug 22, 2006 | 01:47 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
You can try the e-brake if you want to. But I would strongly advise against it. Its possible to powerbrake it, I have done it a few times, pretty smokey.
Old Aug 22, 2006 | 06:06 PM
OceanView's Avatar
W212 & W210
what's the point?
Old Aug 22, 2006 | 09:40 PM
MB AMG's Avatar
2002 E55 AMG
Yes it is possible.
Old Aug 22, 2006 | 11:17 PM
LilFazzl's Avatar
anyone car HOW TO do it? LOL.
Old Aug 22, 2006 | 11:54 PM
Alexbenz's Avatar
Sean's Sister--
2 ways
in the rain............LOL
or if your rear tires are bald.....................LOL
Old Aug 23, 2006 | 12:30 AM
LilFazzl's Avatar
maybe peeel out is hte wrong word but wha ti mean is when i hit the gass itl make the tires chirp, or is that only with launchin with a MT.
Old Aug 23, 2006 | 01:38 AM
MB AMG's Avatar
2002 E55 AMG
Ok, you have to be stopped first. Lightly step on the brake and then lightly hit the gas. Gradually step on the gas hard enough till the rear wheels start to spin. If the car starts to move forward, press just a little bit harder on the brakes (just a bit). After this your rear wheels will be spinning but not your front. After you build up some smoke, let go of the brakes and floor it (if you're not already doing so). Easy!
Old Aug 23, 2006 | 02:22 AM
ReZzZ320's Avatar
Originally Posted by Alexbenz
2 ways
that's just like doing it the easy way LOOL
Old Aug 23, 2006 | 05:19 AM
koskesh's Avatar
1997 E320
in my 1997 e320 i can do it by turning off ASR (so the orange light in the cluster stays on). the straght six engine has so much torque at low rpm that it's almost impossible to keep the tires from chirping at stops.
Old Aug 23, 2006 | 01:55 PM
Alexbenz's Avatar
Sean's Sister--
well, he asked........ahahah
Old Aug 23, 2006 | 04:19 PM
mysticblu999's Avatar
Mercedes AMG
omg lol.... if you are asking how, im not sure you should be doing it in the first place... turn the ASR off hold the brake about halfway then ease the throttle until the back tires spin, it will do it i used to do it all the time in my 97 E320. ill post some pics of me burnin em off! lol
Old Aug 23, 2006 | 04:34 PM
ReZzZ320's Avatar
too bad I can't turn off ASR
Old Aug 23, 2006 | 09:26 PM
LilFazzl's Avatar
Im not tryna burn out!. Just simply hear the tires chirp when i leave the stop sign. like the m5 does with shiftin geras. it chirps. can that be odne with the e320 at a stop? no burnout ****.
Old Aug 23, 2006 | 11:45 PM
perzbenz's Avatar
your sister.
are you 12
Old Aug 24, 2006 | 02:22 AM
ReZzZ320's Avatar
well if it makes you happy then I pulled it off last night. Quite simple though car was stationary, lights turned green, release brakes rapidly and floored it. Quite an annoying chirping sound but still a peal out
Old Aug 25, 2006 | 06:56 PM
OceanView's Avatar
W212 & W210
Yipee, we have a winner!
Do you need new brake pads?
Old Aug 26, 2006 | 03:45 AM
ReZzZ320's Avatar
no not really this was done with new pads
Old Aug 26, 2006 | 11:57 AM
45acp's Avatar
BMW
if you're trying it stationary in a parking lot or someplace you can use some water or soapy water to help the tires break loose.
