outside temperature sensor
Old Aug 23, 2006 | 07:29 PM
sts15's Avatar
2015 E350 4matic Sport and 2011 C300 4matic sport
I have two questions: 1. I let my car sit for three weeks while on vacation and when I started it up the outside temperature guage was un-intelligable. Toggling between c and f, I was able to get it to finally give a number followed by half an F. It now goes to - 98 when it is about 80 degrees out and to -57 when it is about 60 degrees out. It moves very little in between. What gives?
2. Is the automatic airconditioner in any way tied to the outside temperature sensor? It seems that I am having some trouble getting high cooling when the out side guage reads -57 degrees. Any thoughts?--Thanks.
Old Aug 23, 2006 | 08:35 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Sorry, I don't know the answer here, but I have a related question: Where is the outside temperature sensor located on our W210s? Thanks to any, and all, who respond.
Old Aug 24, 2006 | 05:34 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
The outside temperature sensor is on the driver's side next to the fog light. It looks like a black pencil tip sticking out of a little hole in the black plastic. Yes, the outside temperature is one of the inputs into the climate control system. I would check to see if the sensor is in place and not broken. Hitting a parking lot curb can pop the sensor out or break the black plastic panel. The panel and sensor can be easily replaced and aren't very expensive.
Old Aug 24, 2006 | 08:21 PM
Musikmann's Avatar
Thanks for the info Jim,
Musikmann
Old Aug 24, 2006 | 08:57 PM
sts15's Avatar
I went out and rubbed it and pulled it and pushed it and it did not move. But I started the car and the teperature guage worked perfectly. Maybe it was mad about not being used for three weeks...
Old Aug 25, 2006 | 01:22 PM
JimPurdy's Avatar
The sensor snaps into the plastic panel quite snugly. It is easier to pop the panel loose and then snap the sensor out. Try to unplug and replug the sensor into the cable. The problem may only be corrosion in the plug.
Old Aug 29, 2006 | 10:07 AM
sts15's Avatar
Thaks Jim. My guage is now reading right one time I drive and off the next. Where is the panel, behind the bumper? I am illerate when it come to cars...
Old Aug 29, 2006 | 10:22 AM
JimPurdy's Avatar
It is the little black plastic insert in the bumper next to the driver's side fog light.
