Brake pads wear unevenly
Subscribe
Sep 1, 2006 | 12:24 PM
Hey guys, anybody else have this problem? I just changed my front pads last weekend due to the sensor tripping.
I found my right pads work to the sensor but the left pads had quite a bit more left. I changed them previously about 10k miles ago. Is this normal wear? I did replace the rotors this time too.
Another question, when I leave in the morning after heating up the car. I feel a vibration from the rear while driving, it lasts maybe 10 mins then ok. Any idea what it could be?
Thanks,
Sunny
Reply 0
Sep 1, 2006 | 02:40 PM
Hey Sunny your uneven brake wear might be due to bad caliper- sticking .
When you did your brakes last time did it retract ok? and what did you use to push it back?If you used a c-clamp then you might not feel the fault in the caliper.Also I would check , clean or lube the sliding mechanism that the calipers rides on it can hang up and cause the uneven wear too.
Reply 0
Subscribe
Currently Active Users (1)
