Does anyone do A & B services? Why?
Old Aug 29, 2002 | 12:09 PM
Lightman's Avatar
1999 Mercedes E300 TurboDiesel
Just wondering if there is anything they actually do that is worthwhile on these services. I already change the oil myself, air filters, fuel filters(diesel), cabin dust filter, and can rotate the tires. This stuff is easy and mercedes charges a TON. Is there anything worthwhile that i'm missing that they actually do? Aside from checking coolant and battery levels...? Thanks,
Dave
Old Aug 29, 2002 | 01:09 PM
awiner's Avatar
2003 CL55 AMG
Re: Does anyone do A & B services? Why?
Dave
Sounds like you pretty much got it covered. The only thing about the A and B services is that they are free for the first 4 years/50,000 miles for 2000 and newer cars.
Once that period id over, I will stop going in for A and B's too.
Old Aug 29, 2002 | 01:20 PM
Lightman's Avatar
ahh you b a s t a r d s I forgot about that. My '99 is my responsibility to maintain, and I thought a $279 oil change was a little absurd.
What made me even more upset was when the dealer charged me $106 to change my prefilter and fuel filter(diesel).
Since then I learned how to do it myself in 5 whole minutes. I recently bought the parts online for $9. Talk about a ripoff!
Old Aug 30, 2002 | 12:06 AM
phungpho's Avatar
2000 E430 Desert Silver
next time is the coolant !
Lightman,
I think you do a good job, cover almost everything. May be you need to change the 'Coolant' after the first 3 years and then every 2 years (max). I think this is critical for the radiator, water pump, thermostats,..
For the transmission, I think it's life time. About the Brake fluid, they recommend every 2 years but I don't think it's necessary. Maximun, may be every 4 years (I haven't changed it on my Honda since 1991). Oh, don't forget to change the spark plugs every 3 to 4 years or 60K miles. that's it.
Old Aug 30, 2002 | 12:09 AM
Lightman's Avatar
Lol phungpho, can you explain to all of us the process of changing spark plugs on my diesel engine ?
Old Aug 30, 2002 | 12:15 AM
phungpho's Avatar
Really !!!!
No spark plugs on a Diesel engine ???
OK, I learn something today - Thanks
So, you're lucky. On my car, there are 16 spark plugs !
Old Aug 30, 2002 | 12:17 AM
Lightman's Avatar
Lol just teasin ya. Diesels make their power by compression ignition not internal combustion. The compression and heat ignite the fuel, no spark plugs =]
Old Aug 30, 2002 | 09:45 AM
E320's Avatar
You need to change your GLOW Plugs
Old Aug 31, 2002 | 07:46 PM
Lightman's Avatar
Not until one goes bad, or about 100k...
Old Sep 10, 2003 | 04:12 PM
USFBulls's Avatar
2019 E53 Cab
One glow plug went bad on my '99 E300 at 54,000. Mercedes wanted $25 for the plug and 3.5 hrs for the labor ($75/hr). They can replace all 6 plugs in 4 hours.
Old Sep 10, 2003 | 04:54 PM
The Godfather's Avatar
4 wheeled car.
what's the glow plug?
Old Sep 10, 2003 | 05:38 PM
michakaveli's Avatar
E300
I was thinking about replacing the coolant on my E as well. I don't recall from where but is there a solution that Mercedes sells that helps condition the cooling system to break up and clean it free of oxidation and corrision out before you flush the cooling system?
