Bmw 2002 battery died every morning starting
Hi,
Friend I have BMW 2002 ,I have to either put new battery Or change the battery for every morning start car,
My question why the battery die so Fast Plz ur advsie
Even I replace new battery for next day morning i will find car not starting
thx
thx
1997 C36AMG
here is your solution
ok friend, this is what u do, take your car to auto zone, or kragen, or any repair shop in your area,, first let them test your alternator. they should be able to help you with you alternator problem, you need new alternator, old one will not charge, battery which cause battery to die, you can buy a new one or a rebuilt one, but a rebuilt one and make sure the charging amps are the same as what your stock one used to be.
altenator location photo in car
Hi,
some tell "You may have a short somewhere in your system, or it could be a bad altenator "
what is that altenator?Is that device which charge battry ,How can I know altenator is not work or damage.
thx
thx
'97 E420 sport, '89 BMW 735i, '71 '73 BMW 2002, '64 Impala
I have had the same problem with my 2002. I had to replace the plug in harness on the back side of alternator. But you should get your alternator checked to see if its bad before do do anything that major.
1997 C36AMG
under
the alternator is located under the front half of your car, just look right under as soon as u go right under the hood, u may not be able to see it because of plastic soo remoove underbody plastic.
alternator question
Hi,
My can tell what is work of that alternator ?Its this device work to charge battery.that Plz If you be kind can explain more what is that
Second Some recommand "plug in harness" replace what is that Plz If you be kind can explain more what is that.
Can some send photo or link show work of alternator
many thx
many thx
Yes, the alternator charges your vehicle battery. It is driven by a belt. On the 2002 it will be up at the top of the engine. Your best bet is to go to any of your local parts houses and ask them to check it for you.
