AMG Wheels?
Old Nov 20, 2006 | 08:12 PM
dwalker011's Avatar
99 C5 FRC
AMG Wheels?
Does anyone know for sure whether 05' S55 AMG wheels will fit on an 01' E320?
Old Nov 20, 2006 | 08:48 PM
raymond g-'s Avatar
99 E320
unlikely. generally, S models have at least 10mm higher offset than 210s.
also dbl check but it's also likely that the late model S rims require 14mm bolt
to your 12mm - the ball seat of the S is larger as well, so the ball seat of your
210 bolt will have much smaller contact point when torqued to spec onto the
S rim.
Old Nov 20, 2006 | 10:18 PM
dwalker011's Avatar
99 C5 FRC
S rim.
Thanks for the heads up.
Old Nov 22, 2006 | 10:24 AM
raymond g-'s Avatar
99 E320
p.s. i have AMG split spoke off an 05 E55 (which is w211) on my 99 E320
(w210). i used conversion bolts, 12mm with oddball 14mm radius ball radius
to make this work. offset worked out great
Old Nov 23, 2006 | 01:33 AM
Richard / E320's Avatar
2001 E320
For RAD lug-bolts, check out
www.OtisIncLA.com
sales@OtisIncLA.com
Contact them and they can give you specific information regarding wheels and chassis models, and what lug-bolts you'll need. For example, I put W211 wheels on my W210.
Old Nov 24, 2006 | 09:40 AM
fireice's Avatar
500E
Richard, what are the offsets on your 18s.
Nice website!
Jack
Old Nov 24, 2006 | 12:11 PM
2001 E320
Nice website!
Jack
Hello Jack;
Here's the information on my tires and wheels:
AMG 18x8 Style III et30 Silver - Front
AMG 18x9 Style III et39 Silver - Rear
Bridgestone Potenza RE750 235/40x18 - Front
Bridgestone Potenza RE750 265/35x18 - Rear
H&R Springs w/ OEM #2 Pads Front and Rear
I wish I had time to post more information on my website but there always seems to be a million other things to do...
