Lowering my 210 question please
Old Dec 18, 2006 | 09:08 PM
Bossman123's Avatar
2001 e320 2004 e55
Ok I am going to buy these (MBW sponsor) Questions
http://www.tirerack.com/suspension/s...4.2&perfCode=S
Are these the right springs? I want the car to be noticeably low but not ghetto.
Should I spend the money to have a Merc dealer install them or take them to a non Merc reputable shop that I trust.
The thing I am most confused about. Do I need a camber kit and what are these numbered spring pads that I read about. I have searched the forum but I am still somewhat confused. Thanks
Old Dec 18, 2006 | 10:27 PM
Tweel's Avatar
1998 E320 3.2 V6
IF you really want an educated answer...copy and paste this topic here...
https://mbworld.org/forums/wheels-tires-suspension-brakes-forum-36/
Old Dec 18, 2006 | 11:15 PM
husk323's Avatar
Tesla Roadster Sport
yes you need to get a camber kit speedybenz has them. You will prematurely wear out your rear tires if you don't install a camber kit
Old Dec 18, 2006 | 11:43 PM
OldNate's Avatar
1998 E320
Usually, the negative camber can be compinsated for on tire rotations. If you move your rears to your front every 3000 miles you will be okay with a small amount of negative camber. If you have a large amount, which will result in a 1.8 inch drop +, you will need a camber kit.
Old Dec 19, 2006 | 07:07 AM
uberwgn's Avatar
e300d
I've got H&R springs and the Eibach set up for my W210 sedan. What shock are you going to install?
Old Dec 20, 2006 | 10:35 AM
TruE320Ridah14's Avatar
2007 E550
I think the best lowering combo is H&R springs with Koni adjustable shocks.
You are better off getting a camber kit and there is a few out there just do a search.
Old Dec 20, 2006 | 11:36 AM
husk323's Avatar
Most people go staggered with 18's cause you can really wide tires on the rears of the w210's. Wider than the w211's
Old Dec 20, 2006 | 12:56 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
If You Lower the W210 One will need the Front REPAIR Camber Bolts sold by MB X4 that WILL allow you to adjust the Front to Spec
The Rear Camber is Not adjustable unless One Installs a set of camber bars that are adjustable or a Kmac kit
I have used Speedy Benz Adjustable camber bars for seven years without any problems
You can have a Decent tire shop install the springs as MOST Dealers will NOT install lower springs
BTW I would advise you to replace the shocks at the same time as the (OLD) Shocks are at a different height and when you lower the car the shocks will be at a different height..and IF there is any wear on the shock piston it will take the seals out..also on a lowered car one WILL Need shorter shocks as the travel is different
Old Dec 20, 2006 | 01:51 PM
Bossman123's Avatar
2001 e320 2004 e55
Thanks for taking the time to answer my questions guys. I am having it done next Saturday. I'll post before and after pics once its completed.
Old Dec 20, 2006 | 07:28 PM
my E430 rocket's Avatar
BMW X3. R33 skyline
so what was your final purchases going to be.... just the springs? which pads? and are u getting the camber kit?
Old Dec 20, 2006 | 07:51 PM
OldNate's Avatar
1998 E320
that is true, I personally went the same in front and back so I can rotate the tires.:$
Old Dec 20, 2006 | 08:13 PM
Bossman123's Avatar
2001 e320 2004 e55
I am getting the springs I posted. I am gonna lower it at a local shop, then take it to the MB dealer to get advice on the pads and camber kit. I am getting some rims/tires in a few weeks so I'll get new shocks after the new wheels are installed.
Old Dec 20, 2006 | 09:38 PM
BMW X3. R33 skyline
but is it not more economical to put the pads u want on during the spring install?
