1996 E320 super problem
Old Dec 20, 2006 | 09:47 PM
HighRoller's Avatar
E320-SL-300, Stang5.0-Volvo242 and some more
Angry 1996 E320 super problem
I a 1996 E320,the car will NOT rev more than 2400 rpm, if you are park or driven.Example: you are in the stop light and you have to go fast ,the car will star jerking at 2300 to 2400 rpm,but if you take off slowly it will go normal.as long you dont hit the gas to the floor the car will run ok.My mechanic check all this : No code in the comp,MAF,Flywheel,crank sensor,coils,Timing chain,Timing,Throtle assy replace already,New wire harn.., the mechanic dont know what is the problem??????????? what a junk. Any help PLEASE any. Thanks
Old Dec 21, 2006 | 03:27 AM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
If someone tells you whats wrong then please post it up because I also have a 96. Bump for some help here.
Old Dec 21, 2006 | 09:13 AM
martz's Avatar
German
i am no expert , but sounds like MAF issues.....get another opinion. go to the dealer and have them run a Diagnostic ck
Old Dec 21, 2006 | 09:15 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Fuel filter ?
Old Dec 21, 2006 | 09:23 AM
ReZzZ320's Avatar
I agree with the MAF issue as well. Better yet why not pop the hood while the engine is running and pull on the throttle body cable. If it cuts off waay too early then you might have airflow issues.
BTW does anyone know where's the fuel pressure valve on the M104 engines? If so then you can check wether enough fuel is running through the liners.
Old Dec 21, 2006 | 03:47 PM
dcoleman11's Avatar
my 97 e320 did the exact same thing. It was the computer. $1200.00 for the computer and 1 hour to install.
Old Dec 22, 2006 | 01:09 PM
HighRoller's Avatar
I bring the car to the dealer,and after $200.00 they dont know sh***t. the guy in the stealer say is the timing, my mechanic check the timing and was ok.He check the MAF, and is good and disconect like you say and nothing. FUEL FILTER ahh!!! GOOD ONE I will try this. thanks.
Old Dec 22, 2006 | 01:17 PM
C43AMG's Avatar
Veteran: Army
I FUEL FILTER ahh!!! GOOD ONE I will try this. thanks.
Old Dec 27, 2006 | 12:12 PM
citruspilot's Avatar
06 CLS500, 04 Tahoe, 04 Infiniti G35 Sedan, Boeing 737
Did this car get fixed? Just interested.
Jeff
Old Dec 27, 2006 | 08:54 PM
HighRoller's Avatar
Jeff
Not yet ,we will order the comp... and will c.
Old Dec 29, 2006 | 09:12 PM
HighRoller's Avatar
Jeff
I move the car to other mechanic shop and in 2 minutes he say is the MAF!
He have a new scanner and update sofware,I order the part, will be on by tuesday.
Old Jan 1, 2007 | 08:25 PM
Z06EATER's Avatar
1997 C36AMG
sounds like
your sparks are not firing right, or it could be your intake system. the engine is being choked., or u know what it may be the transmission.
Old Jan 1, 2007 | 08:58 PM
mv420xx's Avatar
Originally Posted by C43AMG
Fuel filter ?
+1
from the sounds of it, might be a fuel filter.
example:
when u take off slow not alot of fuel needs to be sucked through the filter, when u hit the gas ur choking the engine cause it cant get enough fuel from being clogged. id try this cheap maintance job before a computer. if its a computer im sorry to hear. try and find a used one. good luck...
Old Jan 18, 2007 | 07:00 PM
HighRoller's Avatar
Finaly the stealer find the friking problem. (3 months later ) Is the F....flywheel.
Old Jan 19, 2007 | 01:45 AM
MB>BMW's Avatar
G63 W463
i had a similar pronlem.....check the sparks...you may be hacing misfire
Old Jan 19, 2007 | 03:01 AM
Tommy_s4's Avatar
ML320, Looking for my S4
i heard this somewhere so it might be your problem. out e's arent drive my wire their eletronic throttel it might a eletrical problem telling the relay that the gas peddle isn't past the 2500 rpm mark.
Old Jan 19, 2007 | 09:48 PM
HighRoller's Avatar
Is just the Flywheel!!! 2 of the little thinguis are bend, and the crank sensor is reading wrong.New flywheel on the way for monday.
