Check Engine Electronics
So, in order to have the code cleared you'll find out what the code is. That will narrow your search. Good luck.
(Edit: Oh well, disregard this post. You found it................
)Jeff
Jeff
Then pry it out and flip it over and replace the cap till it clicks.
If it works there is no need to erase the code the fuel lamp will stop blinking and the cel will go away.
If no work get a new fuel cap from the dealer or autohausaz.com
also don't ever fill up with the engine running and never top off the tank.
Other causes of gas cap warnings and CEL's
