Cruise Control Problem
Old Jan 21, 2007 | 04:27 PM
prostreethotrod's Avatar
when activating the cruise control, it will surge for a second or two and will not hold the speed selected...any ideas
Old Jan 21, 2007 | 04:44 PM
raymond g-'s Avatar
99 E320
and your vehicle is.....? tnx
Old Jan 21, 2007 | 06:06 PM
Tommy_s4's Avatar
ML320, Looking for my S4
lol
Old Jan 21, 2007 | 07:26 PM
OldNate's Avatar
1998 E320
It's most likely a fuse. In the W210, the cruise control fuse is the same fuse as the brake light fuse. If you have a w210, the fuse should be on the side of the steering wheel I believe. Just look through your manual.
Old Jan 21, 2007 | 09:12 PM
raymond g-'s Avatar
99 E320
wasnt trying to be flippant. with yr/model i can check the TSB database. w/o it,
it just ends up being a wag
Old Jan 22, 2007 | 07:42 PM
it's a 1996 e320
Old Jan 22, 2007 | 11:08 PM
EClassBenz's Avatar
E500
quick question. are you having any problems starting the car?
Old Jan 22, 2007 | 11:32 PM
woodylew's Avatar
1999 C43 AMG
Do you have worn front tires & new rear tires or vice versa? If so, your speed sensors are picking up different signals from the tires and turning off the cruise control.
Old Jan 22, 2007 | 11:47 PM
raymond g-'s Avatar
99 E320
woody gets a gold star. here is what i have so far....
Date: December 30, 2004
Order No.: P-B-30.30/61
Supersedes:
Group: 30
SUBJECT:
All Passenger Models Cruise Control Inoperative
For Information Only!
If you receive customer reports in the above model vehicles where the cruise control disengages at highway
speeds, but functions at lower speeds (~25 mph), ensure that a difference in tire circumference between the
four tires due to un-uniform wear is not the cause. Additionally; ensure that all 4 tires equipped on the
vehicle are identical in the following manner; tire manufacture, application (snow, all-season, performance,
etc.), speed, and load ratings.
Note : Version/SCN coding should be considered, if the vehicle recently received a ME software flash or
control module replacement.
If you receive reports in the above model vehicles of the cruise control disengaging, please ensure that the
vehicle's ME control module is properly version/SCN coded.
does this help? i'll keep digging
Old Jan 24, 2007 | 08:11 PM
it began in the spring last year, that i,ve had this problem , my summer tires and now my winter tires, all matching, same tires i've had for awhile,
i'm not having any issues with starting the car...is there a vacumn leak somewhere to look for?
