dash bulbs
Old Mar 30, 2007 | 04:48 PM
daSong's Avatar
2001 W210 E320
dash bulbs
has anyone changed their own dash lightbulbs? the dealer told me it would cost about 200 dollars for them to change it. how difficult is it? are there instructions anywhere?
thanks,
Old Mar 30, 2007 | 06:28 PM
gujupimpster89@'s Avatar
97 e420
i havent tried it, but my dealership said $140
Old Mar 30, 2007 | 07:41 PM
blackduc's Avatar
1998 e 320 4matic,2001 e320 4matic wagon, 1990 Carrera 2
You can find lots of info on this by searching under "gauge cluster removal" or "dash lights". I needed help with this same issue a while back and found lots of tips and advice that way. I was able to replace all the bulbs that were bad, and if I remember correctly, the bulbs were only a few bucks each. Skip the dealer, you can do this yourself and save the money.
I did not have to purchase the cluster removal tool, I was able to remove the cluster without it.
Hope this helps.
Old Mar 30, 2007 | 08:59 PM
JerryCurl's Avatar
Search it out, if you're doing it for cosmetics to change the bulb color, I think the gauge face has an amber tint - so your bulbs will never show a true color (if you can even find corrct colored bulbs).
Buy the dash removal tools unless you can get your hands on some super stiff wire or rod - a coat hanger isn't going to cut it if you have a tight one. I tried all sorts of things and it takes a lot of force to yank it out, so again, it's best to have the cheap tools to do it.
Good luck
Old Mar 31, 2007 | 07:54 PM
mike430sport's Avatar
2000 E430 Sport
instrument cluster removal
It is very easy. All you have to do is get two flat head screw drivers and pop it out from the bottom. What you are going to do is feel for the retaining clips. Once the flathead penetrates the clip you can release the cluster by prying it out. You can pull it out in 2 sec.
