Dust in projector lenses
unfortunately, what gaffer suggested may be the only option to clean but
you really need to be careful. dont try to clean the chrome/silvered surfaces
unless you are sure what you're doing. the polycarb or lexan outer lens
should be pretty basic - prob gentle cleaning with Dawn and clean water
and microfleece rag. unless there is a lot of dust on the glass projector lens
itself, i'd shrug it off.....or try to clean from the rear with lonnnng qtip
surrounding the projector lens will prevent complete rearward removal
out of the plastic surroundings. As such, your only recourse for
certain cleaning is to remove the front plastic outer lens.
Sure, you can inject air, but just be aware that you're just swirling it
around and whatever dust is dislodged may be redeposited onto another
surface at random.
