Car Talk
2015 E350 4matic Sport and 2011 C300 4matic sport
Car Talk
I was listening to CAR TALK this morning and Click and Clack swore up and down that there was no reason in the world to use anything but regular gas in any car except a car that someone drove as a high performance vehicle and cared about the very minor greater HP that you would get. They were very straight about it. They said all modern engines can adjust for ping and while you might not get the same HP, it would not hurt your engine to use the lowest octang possilbe. I love these guys and with the price of 93 near three bucks, I wonder if I used 87 for awhile if they are right? Comments?
1 Post
01' CLK55
I guess Mercedes put "PREMIUM UNLEADED FUEL ONLY" on their cars just for the hell of it =)
But if they put 97-103 in Germany and the best we can do in the US is 93, why would 87 make any more difference? Clearly we do not have the 97 and the cars are still running. Why waste the money?
ok so you'd rather listen to some dudes on the radio talking out of their a$$es rather than the MB Engineers who actually designed & built the cars who specifically state in the manual "Premium Unleaded Gas Only"?
no offense but if you wanna save a few pennies on cheap gas you're driving a wrong car. go drive a toyota prius.
Premium is cheap these days, relatively speaking. It's still only 20-30¢ more than regular.
At $1 a gallon for regular and $1.30 for premium, premium is 30% more.
At $3 a gallon for regular and $3.30 for premium, premium is only 10% more.
The higher gas prices go, the more negligible the difference between the two.
1998 E320
Honestly, you can put normal 87 octane fuel in the mercedes, not much will happen. Our neighbor has a E class with 182k miles and he has been using regular since 40k miles. Although, you shouldn't do this, because i'm sure it does decrease the mileage of the engine in the long run. I run premium 91 octane at all times.
The reason European fuel has a higher octane rating is you use a different formula. Here in the US we use the following formula:
(RON + MON) / 2
In most places around the world (including Europe and Australia), the Research Octane Number (RON) is what’s posted on the pump. There is a second rating called the Motor Octane Number. Both numbers are determined using a variable compression engine, but the MON uses heated fuel, the engine is run at a higher RPM, and the ignition timing is adjusted during the test. The MON is always eight to ten points lower than the RON. This means the exact same 98 octane gallon of UK fuel, is rated at 93 or 94 octane in the U.S.
Modern engines have knock sensors. When the ECU determines the engine is knocking, it retards the timing. The ECU doesn't retard it a little, it retards the timing to "this engine can't possibly knock now" levels. Engines with retarded timing produce lower fuel economy numbers than engines with the factory recommended timing specs. This leads me to believe that the money saved by using lower octane fuel will be negated by the poorer gas mileage. Aside from that, the cost of a single blown head gasket is all it takes to reach the point of never breaking even. All that's being discussed is "saving" a lousy $3 per tank using substandard fuel (15 gallons at a 20 cents per gallon savings). Nothing at my dealer costs $3.
Lastly, here's what they have to say on the exact same subject at their website:
Dear Tom and Ray:
For umpteen years, I have had a choice of 87 octane, 90 octane, and 92 octane gas. I always purchased 87 octane because it was the least expensive. And my cars have always performed well on 87 octane. I now have a car that has a sign on the dash that says "Premium Unleaded Fuel Only." Why does the manufacturer tell me to use 92 octane, and how important is it that I pay attention to this?
Ray: I can tell you're a cheapskate, Norma. They put a big sign right in front of your face on the dashboard so you can't possibly miss it, and instead of spending a few extra bucks a week, you stall, hem and haw, and write to us to ask if you really have to do it.
Tom: Ahh. A woman after me own heart!
Ray: And because you're--shall we say--frugal, you're going to be really bent if you ruin the engine on your new car and have to pay for a new one, aren't you? In which case it's very important that you follow the manufacturer's instructions for octane ratings--whatever they are.
Tom: Here's why. The lower the octane, the lower the temperature at which the gasoline explodes in the cylinders. And in certain "high compression" engines like yours, 87 octane gasoline explodes too early. Those early explosions are known as "pinging" and they eventually cause engine damage.
Ray: Premium gas (probably 91 or 92 octane, whatever is specified in your owner's manual) explodes when it's supposed to in your engine, and that's why the manufacturer of your car requires it.
Tom: In general, you should always follow the manufacturer's recommendation when it comes to octane. Using a lower octane can harm the engine over time, and using a higher than called- for octane is a complete waste of money.
Ray: And I guess that's the good news we can give you, Norma. You don't have to waste your money springing for 94 octane. You can stick with the nice, cheap, 92 octane stuff.
(RON + MON) / 2
Dear Tom and Ray:
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I like these guys too and it's too bad they seem to be expressing two differing opinions, one on their recent radio ralk show and another on their website.
I choose to believe the information MarcusF just posted, and I believe like most of the others, that you should use at least 91 (R+M/2) octane fuel in your Mercedes.
'03 E39 530I
Why can't people decide for themselves? Why do they always seek 'expert opinion', usually from some person not even qualified to do so. Many people ask to be fooled, if that even makes sense. Information is out there. Obviously everybody has differing opinion, and stubborn people will always ignore scientific data, not to mention all the hearsay going around. So, try it for yourself and make your decision? If you dont notice any degradation in performance/gas efficiency, go with lower octane. Your engine wont blow up on a tankful of lower octane.
'99 E430, '05 ML500, '15 GLK350
I will run mid-grade through my Hengst from time to time, however, and haven't noticed any detectable change in performance or mileage.
Ramblin' Wreck '84 BSME
96 and 08 911 turbos
Maybe you can also remind me why the northeast houses the best finance, law, and architecture concerns?
When was the last time a hillbilly knew anything at all, besides how best to sleep with their cousin?
From all the advice, I think I will stick with 91 but dip to 89 every once in a while. There does not seem to be a difinitive answe. Just becasue MB tells you to use primium does not seem to be good enough. Why would they put the sensors and knock adjustments in, if using primium was mandatory. On the other hand, I do not want to say 3 buck a fillup just to lose a head gasket, that made the most sense to me.
On the other hand I think Tom and Ray are right most of the time and they sure are funny.
Where is PIne Brook? I live in Princeton.
rotfl, another genius from down south. Remind me why all the ivy league schools, and the best engineering/mathematical schools are in the northeast?
Maybe you can also remind me why the northeast houses the "best" finance, law, and architecture concerns?
Your last line also shows that you, like nearly all Jerseyites, are living in a fantasy world about what the South is like today - that's not a bad thing if it keeps you in Jersey.
'04 Cobra & '04 S430
Follow MB recommended minimum Octane. It is there for a reason.
For what it's worth, I was suprised to learn that not all modern cars have knock sensors.
Here's the word from Mercedes:
https://www.mbwholesaleparts.com/Sta...June06Star.pdf
With today’s soaring gasoline prices, if your customers complain about poor performance and poor mileage in 1986 or newer models, ask them if they have switched to a lower octane gasoline or ethanol to save money. If they have, tell them to go back to premium unleaded, even if it’s the most expensive fuel available.
Mercedes-Benz is very clear that only premium unleaded is to be used for all gasoline engines since MY 1986, except for MY 1986 190E models with the 2.3L engine.“Gasohol”, which is usually a blend of 90% gasoline and 10% ethanol, may be used. Ethanol concentrations greater than 10% are not permitted except for specially designated “Flexible Fuel Vehicles” that can burn blends up to 85% ethanol/15% gasoline.
Owners of MY 1975-85 Mercedes-Benz vehicles and MY 1986 190E with the 2.3L engine can use unleaded regular gasoline. For MY 1972-74, unleaded gasoline with at least an 87 octane rating should be used.
Before MY 1972, Mercedes-Benz vehicles, like most cars, were designed to use leaded gasoline, which, of course, hasn't been available for many years. These cars, like the younger MY 1986 and new models, need unleaded premium, with an octane rating of at least 91.
Using anything other than premium unleaded in any gasoline engine since MY 1986 is not only discouraged, Mercedes-Benz has a list of recommendations if a driver is forced to use anything else, including:
•Only partially fill the tank with any other gasoline. Drive only until premium unleaded is available. Top off the tank with premium unleaded as soon as possible.
•Do not drive at full throttle and avoid hard acceleration when using anything but unleaded premium.
•If the vehicle is lightly loaded, such as no more than two occupants with no luggage, engine speed should be kept below 2,000 rpm. If the vehicle is fully loaded or operating in a mountainous area, do not exceed 2/3 throttle position.
•The only fuel additives recommended are detergents and other additives blended with the gasoline during the refining process by the petroleum company.
According to Mercedes-Benz, “DO NOT blend other fuel additives with the fuel. These additional additives only result in unnecessary cost and may be harmful to engine operation.”
The only exception to the “no additives” rule is Mercedes-Benz’s own additive, (Part Number A 000 989 25 45 10). Follow the specific directions when using this to remove internal carbon build up on valves because a high quality gasoline with detergent additives was not regularly used in the car.
