1997 E320 Flip Key Remote Question
Old Apr 19, 2007 | 11:16 AM
jaamb85's Avatar
1997 E320 90k
Has anyone had any trouble with the older style flip out key remote?
My remote doesn't always unlock the car by using the IR button. Sometimes I have to press it 5 times before it unlocks the car. I think maybe it's because the key fob might be coming apart and causing the batteries to come apart and maybe resetting the codes? Maybe I just need to buy new remotes...
I am considering installing a key lock in my driver's side instead of the IR senser with the Red/Green lights. It is broken anyway from stupid valet drivers trying to shove my key in it. Has anyone had any experience with this?
I want to be educated before I go to my mechanic/dealership
thanks!
Jason
Old Apr 19, 2007 | 12:55 PM
loubapache's Avatar
2003 E320 4Matic Wagon & 1997 E320
Weak remote battery?
Old Apr 19, 2007 | 01:09 PM
E-Klasse's Avatar
W205 C300
Are you pointing it at the rear view mirror when you push the button. Try a new battery in the remote. A new remote will cost you $150 from the dealership. It has to be programmed for your car.
Old Apr 22, 2007 | 10:29 PM
jaamb85's Avatar
1997 E320 90k
Sometimes, usually during the day, I will be standing infront of the driver's side door pointing the remote at the rear view mirror and it will open after 3-5 pushes of the button on the remote. Sometimes, it doesn't work at all and I have to go to the trunk and unlock the car. The same situation goes for the trunk receiver. I don't think the batteries are very old but I will try replacing them tomorrow.
It's strange but I think I have a higher success rate with the remote at night. Maybe the IR signal, as stated above, is weak and the sun makes things worse. If i hold the button down on the remote it does blink once I believe. Doesn't that mean the battery is fine? I'll change the batteries anyway and post what I find.
Jason
