CD Changer Skipping
Old Apr 25, 2007 | 05:32 PM
lukejs's Avatar
Exclamation CD Changer Skipping
I have a 2001 E320 Wagon with the mc3010 changer. I have the horizontal/vertical setting set, but it it still skips quite a bit. It is securely installed in the bracket area. Any ideas?
Old Apr 26, 2007 | 02:06 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I don't know the model numbers, but MB/Alpine improved the later changers from what I've heard. My used 2001 E320 did not have one, and I bought mine off a guy on eBay that had came from a newer-than 2001 car. It works well.
Old Apr 26, 2007 | 02:35 PM
loubapache's Avatar
2003 E320 4Matic Wagon & 1997 E320
Here is my experience:
1) the changer on my 1997 E320 never skipped, not even once.
2) the one on my 2003 E320 wagon 4Matic (W210) skips often.
Old Apr 26, 2007 | 03:11 PM
raymond g-'s Avatar
99 E320
MC3010 is suppose to be more skip resistant than the MC3198 it replaced. I
believe MC3111 can be used also as it should be D2B compliant also. but if
you did adjust for H vs V, i'm not sure why it would continue to be so sensitive.
the drive mechanism rides on 4 gell donuts. perhaps it has disconnected from
these cushions?
Old Apr 26, 2007 | 03:20 PM
loubapache's Avatar
I thought logic would work that way as well but it is MB so noone ever knows.
Obviously the one on 2003 is fiber and much newer but it just skips more than the one on 1997.
Old Apr 28, 2007 | 11:42 AM
ccmbduong's Avatar
The laser beam to read CD is on its way out... Eventually it will get worse. It happen to my CD in '96 E320 , bought a new unit and have not skipped a beat..
