Squeeky Door Hinges
Squeeky Door Hinges
I have a '96 W210 E300D with 165k miles on it. All four of the door hinges squeek. Is there an easy fix or do I need to replace the hinges themselves? I suspect this is normal with the age and wear of the car. I am the fifth owner.
Thanks!
Thanks!
If you take your car in every 30k miles for service, as the manuf. recommends then they will lube the doors for you. If you have been to the service and there is still a squeak then there might be another problem. If you dont service your car, and it squeaks, then use lithium grease or some wd40.
1 Post
2003 E320 4Matic Wagon & 1997 E320
If it is a clunk type of noise, then it is the door check. It is that thin piece of metal that goes all the way into the door. It is between the top and bottom hinges.
You'll see there are very thin grooves on that check (both top and bottom). Try to lubricate these grooves to see if the noise goes away. Otherwise you may need new checks. They are inexpensive but the door panel has to come off.
2001 E55 Silver with Charcoal/Ruby
Did you do it?
I've tried lubricating and mine aren't getting any better. I'm looking for advice/input on how to replace the door checks. Did you do it? If so, how difficult was it and do you have any helpful tips?
'97 E320
Thanks for the direction on this one guys (or gals). My front doors are doing the "clunk and squeek" @ 118K miles...and neither type of lube has solved the problem. Now I know what to chase!
'97 MB E420 Sport/'88 MR2
