Malfunction Msg displayed
Old May 1, 2007 | 12:42 AM
victorylap's Avatar
2000 E320, 2007 Land Rover LR3 HSE, 2008 E350
On my way home from work, I got an ESP Malfunction Msg followed by BAS, ABS malfunction msg. Per the Operator's Manual, the ESP indicates it may be caused by power supply was interrupted (battery disconnected or empty). Does this mean I need to replace my battery? I'm also concern why the ABS-BAS (brake assist) malfunction/warning Msg indicator came on also. Appreciate any feedback.
Old May 1, 2007 | 01:17 AM
Lancelot's Avatar
'01 W210 E320 CDI
They're all related, using the same sensors...
Old May 1, 2007 | 10:21 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Its likely that its a bad brake light switch, easy fix
Old May 1, 2007 | 12:13 PM
victorylap's Avatar
Sosh - if it's a brake light switch - what is need to correct or fix this minor problem? thanks!
Old May 1, 2007 | 12:29 PM
sosh's Avatar
New Brake light switch. Be certain to use the correct MB switch. I also suggest you have it correctly diagnosed before throwing parts at it. Well worth the few bucks it costs and the switch is not expensive.
Old May 1, 2007 | 01:19 PM
victorylap's Avatar
Thanks - good info!
Old May 3, 2007 | 09:56 AM
mbnj's Avatar
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
Give them your VIN when buying (like $15), they gave me the wrong switch the first time and I took the whole thing apart and wouldn't fit. Check old posts on removing covers and location of switch.
Old May 3, 2007 | 05:36 PM
urHoneyinmy420's Avatar
e420
ive experienced the same thing
hey that happened to me before when i put on new rims. i had a bunch of malfunction messages pop up so i took it to my repairman. he told me that the brake sensors or something might have been messed up. i decided not to do anything about it, and one year later, there hasn't been one message.
Old May 7, 2007 | 08:27 AM
sts15's Avatar
2015 E350 4matic Sport and 2011 C300 4matic sport
Let us know what you find. Those same lights come on on my car randomly about once a week. After a restart of the car they are gone. I have no idea why they come on. sometimes when I am cruising, sometimes when I put on the brake, and most of the time the are not on. any clues would be welcome.
Old May 7, 2007 | 04:29 PM
victorylap's Avatar
It was a faulty brake light switch - luckily, my starmark extended warranty covered the part and labor cost which fixed the problem (pheww), but, I understand its a pretty simple task and the part cost $20 for the brake light switch.
Old Aug 25, 2007 | 11:58 PM
HeyD's Avatar
where can i buy a brake light switch? Thanks
2004 mercedes c230 sedan
Old Aug 26, 2007 | 06:55 AM
4runner's Avatar
Purchased mine from the dealership, cheaper than any online offer w/shipping cost. I dont purchase much from the dealer, but when the cost is less than $20, if just makes more sense.
