E300D Front Control Arm Re-Install w210
Old May 5, 2007 | 09:45 AM
michakaveli's Avatar
E300
Since I am replacing the OEM springs with some E55 springs, in addition to all the required bushings and such I bought the E55 lower control arm camber bolts. The bolts that were on there previously were nothing special, normal looking bolt with a flat round washer. The new replacement bolts look much more interesting.
The washers have a notch in them that stands out on one side, almost looks like the can fit into the grooves in the lower subframe mounting holes. I am ASSUMING that the notched side should be facing the control arm, correct? This is how I can interpret the photos from the WIS program. I've added a photos to show how I installed the bolts with the washers onto the arms.
Also, the front bolt would not fit back in like the one I removed. The original bolt seemed slightly shorter and was a tight fit to remove as a line to the transmission cooler runs right in front of the front bolt. In the photos I installed this bolt in the reverse, such that the heads of both bolts face each other on the inside. Is that ok? I am adding a photo of the other side how it looks as I have not yet touched it.
I've tightened the bolts so far to be snug but not tight as I assume the alignment tech will be loosening and re-tightening them to perform the alignment. Am I missing anything else?
Attached Thumbnails E300D Front Control Arm Re-Install w210-dsc01070.jpg   E300D Front Control Arm Re-Install w210-dsc01071.jpg   E300D Front Control Arm Re-Install w210-dsc01075.jpg   E300D Front Control Arm Re-Install w210-dsc01076.jpg
