2005 W320 Wheels on my 1997 E320??
Old May 9, 2007 | 12:56 PM
jaamb85's Avatar
1997 E320 90k
Will a set of 2005 E320 wheels fit on my 1997 E320? I am pretty sure the tires are the same if not similar. I'd appreciate any comments.
Rim Width: 8J Tire Width: 225
Rim Diameter (inches): 16 Aspect Ratio: 55
Offset: 36 Load Index: --
Number of Bolts: 5 Speed Index: --
Bolt Pattern: 5 X 112 mm DOT: --
Rim Brand: Factory Tire Brand: Michelin
Rim Structure: One Piece
Jason
Old May 9, 2007 | 01:40 PM
mrbill222's Avatar
1997 E420
i did this on my 97 e420 no problem
had to get new lug's
check out the folowing link
he spells out everything
http://www.geocities.com/mymercedesbenze320/
Good luck
Old May 9, 2007 | 01:51 PM
raymond g-'s Avatar
99 E320
your new rims use larger bolt diameter (14mm) than your 97 (12mm). the corresponding ball seat is also different. so yes, read carefully what Richard/E320
did with his car. I've done same with my 99 E320...and I currently have 05
E55 rims.
