Rough Idle! please help
I searched throughout the forums and found the causes of my problem to be either Motor mounts, MAF,Spark plugs, or Harmonic balancer. I have replaced my MAF about 3 months ago, so I hope it is not that. I don't think it is the motor mounts because wouldn't that cause vibrations at all speeds? And I know nothing about the harmonic balancer. PLEASE, any help would be appreciated.
the harmonic balancer recall has to be done DEPENDING on your vehicle year
if ur not the first owner and have not had it replaced call ur local dealer and theyll run your vin and tell you if its been done or not. Regardless if thats the problem... you should call and see if its been done.
Its free....couldnt hurt
that may solve ur problem....
because bad blugs could cause misfire...as well as bad coils
if uve cleaned ur MAF already, that wouldve been the problem but in ur case it shouldnt be
hope this helped.
Also, Wouldn't the harmonic balancer cause the car to be rough at all times (not just idle)?
ur problem sounds like a mix of good/bad fuel....
next time u need to fill, use the highest grade available and see if theres any difference.
If you are getting a vibration and hum - motor mounts. Have somebody gas your motor with the hood up - if your motor jumps, it's the mounts.
Mine went out, same symptoms. $400 stealership fix - others have changed them about, but no thanks, I still don't know anybody can get a factory spec/torque on some of the bolts which need to come off.
it all started with little vibration when in gear then gets worse
over a period of time (months) ... in gear, in park, in neutral vibration all
over but never when the car is moving.
good luck.
