Bilstein HD's w/ 4Matic.. Do They Exist?
thus narrowing the availability and selections somewhat. i've not come across
a bilstein in coil over design.
i'm not 100% sure of this, however. havent tried to pimp my 4matic to any
degree save for leather Smartkey cover. all my mods have been to the
pre-facelift, garden variety 1999 w210
Here's the link for Bilstein HD's for 4Matic W210's:
http://catalog.worldpac.com/mercedes...tion=000875144
A: depends on the Brabus springs. how much shorter are they compared to
your current, OEM springs? if over an inch and a quarter, you should probably
hunt down a shorter shock.
Q: I thought that the HD's were the same height as the OEM shocks....(?)
A: Based on my experience with RWD Bilstein HDs, the HDs are pretty much
the same length of the soft, stock shocks...though approx 10% more in
rebound damping
Q: besides the hook-style spring compressor that ohlord posted, would
4Matic spring and shock removal be any different than the RWD version?
A: yes, as alluded to earlier, you may need to tool to remove a retaining
plate which acts as a spring stop at the top end of the coil/over unit. the
bottom of the spring is anchored by that metal 'stirrup'...whereas the top
should have a round metal plate with a slot cut 1/2 way through the donut
and which allows it to ride around the piston shaft.
alldatadiy.com for the procedure or get a one day membership to starteckinfo.com and get the factory wis and anything else you can copy in a day.
you are on your way,just be extra careful around springs a few industrial zip ties secured around the suspension while working to get the springs compressed is always a good idea.Take pictures to build a diy for members and also to keep track of the order of the bolts,nuts,and washers.
ohlord
