Bose amp wires...
Old Jun 8, 2007 | 11:58 PM
FlaBoy239's Avatar
Bose amp wires...
Does anyone know which wires on the factory harness go to the bose amp?
Old Jun 9, 2007 | 03:25 AM
lxl_Jeffro_lxl's Avatar
1987 E300 TD
Maybe this helps?
Originally Posted by lxl_josh_lxl
Thought this might help some people who are considering new speakers or changing the gauge of their wire or w/e! I had a difficult time finding it so I thought I would save time for others. This is also the amp in my 1999 Mercedes E300 TurboDiesel
Bose Amp
Left/Right Audio Power Amplifier (N40/3)
Part # 210-820-2689
1 Circuit 30, F4-16
2 Ground (W6)
3 Right rear speaker (H4/8) (-)
4 Left rear speaker (H4/7) (-)
5 Right rear door speaker (H4/4) (-)
6 Left rear door speaker (H4/3) (-)
7 Right front door speaker group (H4/2) (-)
8 Left front door speaker group (H411) (-)
9 Right NF signal (+) from A213
10 Circuit 30, F4-16
11 Ground (W6)
12 Right rear speaker (H4/8) (+)
13 Left rear speaker (H4/7) (+)
14 Right rear door speaker (H4/4) (-)
15 Left rear door speaker (H4/3) (+)
16 Right front door speaker group (H4/2) (+)
17 Left front door speaker group (H4/1) (+)
18 Left NF signal (-) from A2/3
19 Control voltage from A2/3
20 Fader switch (R26) (-)
21 Fader switch (R26) (+)
22 Fader switch (R26)
23 -
24 Right NF signal (-) from A2/3
25 Center fill tweeter speaker (H4/11) (-)
26 Center fill tweeter speaker (H4/11) (+)
27 Left NF signal (+) from A2/3
Old Jun 9, 2007 | 09:36 AM
DG E300's Avatar
'98 E300 TD
lxl_josh_lxl >>
Nice to know - thanks for posting!!
Old Jun 9, 2007 | 11:05 AM
FlaBoy239's Avatar
I don't understand how that helps me locate the Bose wires on the back of the stock radio. That looks like it is at the amp itself. I don't even know where my amp is. I want to hook the Bose to my RCA outputs put don't know which wires to hook the RCA's to.
Old Jun 9, 2007 | 11:55 AM
Down South's Avatar
Amp is on the left side of the trunk behind the carpet panel thing!
Old Jun 9, 2007 | 05:16 PM
1987 E300 TD
Can you give me a year and a model of which car you have? It varies somewhat on pinout diagrams for the stereo headunit
Old Jun 10, 2007 | 05:40 PM
FlaBoy239's Avatar
I figured everything out. I keep reading to splice RCA's from the the new head unit's outputs because they are 4v but I just hooked up the VW harness and it sounds way better than the becker. It seems to be working perfectly with no volume issues as I have read other people are having. Cranks very loud with no distortion. My head unit is the Alpine CDA-9885. I highly recommend.
Old Jun 10, 2007 | 09:36 PM
Down South's Avatar
That Alpine is one that I have been looking at for weeks...can you post a pic of it in your dash????
Old Jun 12, 2007 | 08:50 PM
FlaBoy239's Avatar
Here ya go....
Old Jun 12, 2007 | 08:59 PM
Down South's Avatar
Here ya go....
Thanks a mill sir, consider it bought!
Leon
Old Aug 27, 2007 | 06:15 AM
davaid's Avatar
Mercedes W211 E80 Model 2009
Here ya go....
Hey thanks god I found someone with this headset; I want to get one myself too; is it better that the factory stereo in terms of audio quality, bass effects and deep, surround effects. I have the SPS-17C2 Alpine speakers 2 of them in the front doors and another two in the rear deck...
What about the installation of this Audio does it require any customization or is it just a matter of just plug and play (remove the old factory cassate stereo with this one)?
What about the radio antenna (as I don't know where it is located in my car the stereo guy technician told me its integrated in the glass is it!!) he claims that I have to use another antenna for the radio; is that true or will it be working perfectly on the car factory antenna?
Old Aug 27, 2007 | 07:02 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I thought the antenna was integrated into the glass too, and it still might be. However, I just attended an MBCA event and a guy there (E430 owner) told me our antennae are in the rear and accessible through the trunk in some fashion. This might be mentioned in our owner's manuals, but I don't remember seeing it.
Old Aug 27, 2007 | 12:19 PM
ajent420's Avatar
2002 E320 4MATIC
Look at pic Sub...14, that's the amp in that pic.
http://www.flickr.com/photos/sterwald/
