what is diffrent?
Old Jun 9, 2007 | 03:21 PM
all398's Avatar
what is diffrent?
what is the diffrent between E320 engine with 6 sparks and E320 engine with12 sparks?
Old Jun 9, 2007 | 03:29 PM
ohlord's Avatar
Smile dirrenence?
6 spark plugs!
only jesting,
the older 320 had a straight 6 with 6 plugs and the later models late 98 and up changed to a v6 with more oomph and 12 plugs,2 per cyl
Old Jun 10, 2007 | 11:16 PM
lkchris's Avatar
'10 CL550, '12 GL550
The V6 is lighter, more economical, and more powerful.
You'll be safer in an accident with a V6 vs an inline 6, too.
Old Jun 11, 2007 | 01:22 AM
Crazy MB Rob's Avatar
currently drive the 83 300SD
97 E320 with M104 INLINE 3.2L 6 CYL.
20 mpg City / 27 mpg Hwy
Horsepower 217 @ 5500 RPM
Torque 232 @ 3850 RPM
Valve Train - Double Overhead Cam
Valves per cylinder - 4 (24 total valves)
Spark Plugs - 6
Vehicle Curb Weight - 3605 lbs.
98 E320 with M112 V6 3.2L
21 mpg City / 29 mpg Hwy
Horsepower 221 @ 5500 RPM
Torque 232 @ 4800 RPM
Valve Train - Single Overhead Cam
Valves per cylinder - 3 (18 total valves)
Spark Plugs - 12 (2 per cylinder)
Vehicle Curb Weight - 3460 lbs.
Old Jun 11, 2007 | 08:09 AM
sts15's Avatar
2015 E350 4matic Sport and 2011 C300 4matic sport
Haas anyone gotten 29 MPG on the road? My best is about 25, if I start counting when I am going 60 MPH or faster.
Old Jun 11, 2007 | 10:38 AM
bmwk100rsa's Avatar
w210 e320 wagon
I just bought a 2001 E320 wagon about a month ago and got 28.3 on the trip computer, set at 74mph for 60 minutes. I haven't done any fluid or plug changes yet, but did get the k&n last week. advance auto parts have them for 25% off right now.
Old Jun 11, 2007 | 11:06 AM
lkchris's Avatar
Under no circumstance install the K&N.
You'll ruin your MAS sensor and achieve NO/ZIP/ZERO power benefit.
K&N are 110% hype and less than zero benefit.
Old Jun 11, 2007 | 11:37 AM
ohlord's Avatar
Smile k/n
ditto to that the oil will mess up your maf and you will be sol
ohlord
Old Jun 11, 2007 | 10:08 PM
FlaBoy239's Avatar
ohlord
What!! I've never heard that before. Is this true. I have one and have had no problems.
Old Jun 11, 2007 | 10:40 PM
Bossman123's Avatar
2001 e320 2004 e55
I get 29.8 mpg at 70 after about 30 mins of cruisng. Take it up to 80 and it drops down to 27.1 big difference in the two speeds. 70 it is.
Old Jun 12, 2007 | 02:07 PM
Air Marshall Eldritch's Avatar
John Deere
How many times must we correct people who come here with bad information about K&N. The idiots who can't follow directions over-oil the filter.
I think this around the 47th time I've had to correct this after driving around for almost 110,000 miles on K&N.
Old Jun 12, 2007 | 02:20 PM
ohlord's Avatar
Smile k/n
Oh,
you mean the idiots that come into a shop with a failed maf and a brand new factory oiled k/n filter.You have been one of the lucky ones and I hope you remain that way.For 16 bucks I will replace a filter every year and flow more air and not have to throw in a maf insert when it gets damaged.Other shops in the area bmw etc. also rec against k/n,it's fine on my 57 belair but that is a carb car,if you can think back that far.
ohlord
Old Jun 13, 2007 | 02:01 AM
ohlord's Avatar
Smile read the air filter test above RBRENTON
I rest my case.
Old Jun 13, 2007 | 11:48 AM
lkchris's Avatar
Yes, the mere presence of a K&N on a new Merc will kill your warranty.
Plus, the K&N offers absolutly ZERO advantage in any event.
Your Mercedes engine is NOT STRANGLED by the OE air filtering system, and if you believe it is you're a candidate to be sold the Brooklyn Bridge. If you've bought one already, you've been screwed.
The ONLY way an engine will intake more air is to change valve lift/timing, enlarge valves, change displacement, or turbo/supercharge. A mere change of filter--or even taking the filter off--does NOTHING.
Old Jun 13, 2007 | 12:51 PM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
:x
Old Jun 13, 2007 | 01:18 PM
ReZzZ320's Avatar
you make a horrible mechanic
