sun sensor replace
Rating: Thread Rating: 3 votes, 5.00 average.
Old Jun 14, 2007 | 12:34 PM
KADE's Avatar
2018 W222 S-560 4-Matic
sun sensor replace
Anybody ever do a sun sensor replacement?
Did diagnostic code check..and says bad sun sensor.
All I know is that it's that small black piece on the center dash, near the defrosted vents by front windsheild. LQQks like a hard spot to get to!
Old Jun 14, 2007 | 12:56 PM
raymond g-'s Avatar
99 E320
use your fingernail.
pull up.
swap out.
push down.
15 secs
Old Jun 14, 2007 | 01:05 PM
KADE's Avatar
Thanks raymond, Had no idea it would be that simple
pull up.
swap out.
push down.
15 secs
Old Jun 14, 2007 | 01:39 PM
E420SportGT's Avatar
'97 MB E420 Sport/'88 MR2
what's the sun sensor for?
Old Jun 14, 2007 | 02:24 PM
'91 300CE's Avatar
2000 C230K and 2002 ML320
It keeps track of the position and intensity of the sun and adjusts the climate control on both sides to compensate.
Old Jun 14, 2007 | 03:21 PM
ohhhhh I thought the AC just has a temp sensor one on each side haha.
thanks
Old Jun 14, 2007 | 03:30 PM
KADE's Avatar
And the ambient temp sensor sticks out just beside the driver fog light, which gives you the temp. reading on the inside dash cluster at least on my 2000 thats were its located.
thanks
Old Jun 14, 2007 | 07:54 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
ohhhhh I thought the AC just has a temp sensor one on each side haha. thanks
Two different things. Sun sensor senses sun (light in other words), temp sensor senses temp. There are some of both on your car; internal and external for the temps.
Old Jun 15, 2007 | 01:06 PM
KADE's Avatar
Okay does anyone know the part number for the sun sensor
One dealer says he couldn't find it at all, after I gave him my vin# Another dealer said he'll call me back; And I could not find it on any benz parts websites.
Raymond.....any suggestions?
Old Jun 15, 2007 | 05:28 PM
raymond g-'s Avatar
99 E320
bookmark this site....
http://www.detali.ru/cat/oem_mb0.asp?TP=1
found part illustration, then xref the # over on OEMPARTSDIRECT web site...
shown below
Old Jun 15, 2007 | 05:47 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
shown below
Raymond, I was under the impression that the sun sensor would always display fault in the diagnostic even if it was good and working. Did you replace yours? and if so did you recheck the diagnostics again to see if it was working?
Old Jun 15, 2007 | 05:53 PM
raymond g-'s Avatar
99 E320
you may be correct. mine showed up under fault code. no, i did not replace
based on similar understanding as you.
Old Jun 15, 2007 | 06:34 PM
OK thanks, cause I tried to check it out in the sun and in the dark and got a sun sensor fault both times, but my A/C works quite well and is still on the factory charge.
Old Jun 15, 2007 | 08:09 PM
Down South's Avatar
shown below
When i go onto that site and click on my model "E320", nothing happens after that. The page is black and at the bottom it say "done"
Old Jun 15, 2007 | 09:32 PM
raymond g-'s Avatar
99 E320
is the page displayed really black in color? did you scroll down?
Old Jun 15, 2007 | 09:44 PM
Down South's Avatar
I meant to say "Blank", but I figured it out now...Thanks
Old Jun 15, 2007 | 09:49 PM
Down South's Avatar
Old Jun 18, 2007 | 02:22 PM
KADE's Avatar
Thanks again raymond, everytime I search in the parts section on multiple website's, I could note find it under word "sun sensor", but maybe now with the part number# I can located it.
So do you think its defective? or just getting a false read out from the ac diagnostic test?
I'm not having any problem, but felt that if I got that malfunction code maybe it was on the fritz I guess as they say, "if it ain't broke don't fix it"
shown below
Old Jun 18, 2007 | 03:44 PM
ohlord's Avatar
Smile sun sensor
Read my post from last week about a/c tips.The sun sensor will have no detrimental affect on your a/c operation,so fix or not you are ok.Clear the codes as instructed and see if it stays cleared.
ohlord
Old Jun 18, 2007 | 04:54 PM
phil55's Avatar
2001 e55
http://www.pelicanparts.com/euro/cat..._pg2.htm#item9
Old Jun 19, 2007 | 11:09 AM
KADE's Avatar
Thanks for the sight phil55
Old Jun 19, 2007 | 11:59 AM
KADE's Avatar
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
