help with 2000 E430 cd changer and phone please
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
ok well we have bought a 2000 E430 and when we press cd it says no magizine so we went out and bought a new magizine for the e430 and the problem is we dont know were to find the place to put the magizine...and the owner manuel is for the wrong class lol.anyways so i would apreiteate it if someoen could tell us were to find the area to put in the cd magizine.
also about the phone theres a wire in the middle box for a phoen and we were wondering if you could add your own phoen to the plug or if u have to use a mercedes phone. and if we can use our own cell phoen do any of you know were to buy an adapter for lets say a trio 650?
all help is greatly apretiated(i cant spell can i......)
ur cd changer could be in two places
glove box
or
trunk
for the e class, it most probably is in the trunk.
go to the left side of your trunk and the cd reciever should be tucked away there
lift up the cars cover.
slide the black plastic changer cover
and insert your cd magazine(hopefully filled with cd's
) there is an arrow to which side should be inserted
as for the phone charger...you dont have to use a mercedes benz branded phone, but it needs to be a motorola phone that can receive that input to charge it(preferably an older phone)
hope this helps!
glove box
or
trunk
hope this helps!
If it isn't in the car, then command will not show it. I did installation of changer myself, so before the car didn't have any changer options in menu, but after installing it started talking about it. What it can be, that changer was installed then removed without proper ending bus loop. Actually I also forget where I put a small connector, so if I sell my car and decide to remove the changer, then I can introduce a similar problem.
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Phone
I think to have your car work with a phone it is easiest if you have a Motorola v60 cradle w/associated hardware installed. That way you can buy the MB Bluetooth puck and plug it into the old v60 cradle. Then all you need is a MB-approved BT cell phone (I use a Moto RaZr).
