Frozen right rear after snow tire/wheel install
Old Oct 16, 2002 | 08:02 PM
HJFederoff's Avatar
E430
After swapping my summer tires for identical size snows on aftermarket wheels (same size) the car appears to have emergency brake still in the on position. Attempting to move rearward elicits a rear localized grabbing noise that is accompanied by braking. Any ideas or suggestions would be helpful.
Howard
Old Oct 17, 2002 | 06:15 PM
dallasdriver's Avatar
99 e430 Green
This works on my friends old jeep, his e-brake would get stuck all the time, and what we did was the dealership told him to do was put it in reverse and rev the engine with the brakes on, and at i high rpm pop it, like a drag start 3,000rpm and that worked for his car, but on my car I would call up the dealer.
Old Oct 17, 2002 | 06:17 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
are you sure that the lug bolts for the aftermarket wheels are the correct length
if not ,if they are too long you have just done about 880.00 damage to the parkign brake assy.
Old Oct 17, 2002 | 09:15 PM
HJFederoff's Avatar
E430
DSMIT,
You were correct. The lug bolts used were several threads too long and did indeed damage the e-brakes bilaterally. The bill was about half that amount.
Thanks for the reponses.
Howard
