whining noise/transmission slipping!!!!
Old Aug 2, 2007 | 06:54 PM
topdeez's Avatar
2012 E350 4matic/97 e320 and 01 ml320
whining noise/transmission slipping!?!?!!
97 E320, 72000miles.... I recently started to hear a whining noise coming from my engine. It gets louder with acceleration. I did a search and another member fixed his problem by changing his idle pulley.
When I drive my car like an old man all is well until I step on the gas. This is when the noise comes on and then here's the F*^%ed up part, my transmission does not want to switch gears. It usually gets stuck in 1st or 2nd after I leave a stop light. Now if I turn the car off and wait 2mins and then start to drive again, all is well....then it happens again.
I did change my idle pulley, but the problem is still there. The transmission does not go crazy if the whining noise is not there but again after a while the problem occurs. Can anyone help me out?
Thanks...Rock
Old Aug 3, 2007 | 02:07 AM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
97 was the first year the W210 use 772.6 trans, which have some problem as mileage rack up. They upgrade some of the flaw part in the late 99-00 model year.
Check with the trans shop. If it's one (or more) of the four key set that go out, then you can rebuild the trans, price is all over the place, I would try AAMCO. I rebuild the trans last year for $1600 (my friend shop). First key set toasted, but I think my friend just replaced all four.
Now, back to the earlier part, the early 772.6 have weak planetary gear bearing & axle. If this start going, don't bother rebuild the trans, get a manufacture rebuild one, or get a trans from 99 from junk yard. If the planetary gear start going out, you would start hearing a howl as you speed up, and car is lazy to shift. Replacement of trans w/ one that have updated design (pretty much a new trans) would be quite pricey.
If you intend to keep the car, fix the trans early.
Thanks...Rock
Old Aug 4, 2007 | 08:42 AM
topdeez's Avatar
Thanks Zam, i"ll take it to AAmco Monday.
(by the way, the problem arose prevent me from getting back to you)
Rock
Old Aug 10, 2007 | 12:22 PM
topdeez's Avatar
$3700 later...car drives like new...
Rock
