Headlight Aim Adjuster Not Functioning
Old Oct 21, 2002 | 03:04 AM
tj99e320's Avatar
1999 E320 - Desert Silver
Found my first defect in my recently-purchased 99 E320.
The right Vertical headlight adjuster does not work.
The left one works just fine, so I know I'm making the
adjustments correctly.
I'm wondering it it'll be covered under the Basic Warranty (I've got 8 months left on it). I wonder if the dealer will deem it damanged due to improper use...my nearest dealer is 80 miles away.
The right headligth is very high (hi-beam high). Anyone
know if and how I can fix this?
Thanks,
TJ
Old Oct 23, 2002 | 12:33 AM
yipikaye's Avatar
2000 E-class
I dont know that we can adjust the headlight position. How and where is the adjuster?
thanks
Old Oct 23, 2002 | 12:49 AM
paomien's Avatar
From: Long Island, NY / Mississauga, Ontario / Changhua, Taiwan
11 S550V4
The adjusters are those grey round things you see above the lights when you open the hood. That should be covered under the factory warranty (my warranty expires on the 31st, I'm trying to find anything wrong with the car so i can bring it in before it expires hahaha even though i have the mb extended warranty)..the only thing I can find wrong is the driver's side dome light just stopped working.
Old Oct 23, 2002 | 04:39 PM
tj99e320's Avatar
Headlight Aim Adjusters Locations - Pix
Here's the pictures of my 99 E320's Headlights from an open hood facing the car.
<img src="http://members.ispwest.com/tvasquez/E320/headlights.jpg">
The passenger side vertical adjuster is not working on mine.
TJ
Old Oct 23, 2002 | 11:54 PM
yipikaye's Avatar
2000 E-class
Wow Thanks a lot tj99e320, that really helps me find the knob
thanks
Old Oct 25, 2002 | 09:37 PM
tj99e320's Avatar
Headlight Assy. Replaced
Took my E320 in to have the light checked today.
They replaced the whole assembly. Now maybe I won't
annoy the cars in front of me.
TJ
Old Aug 26, 2004 | 07:31 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
TJ99e230,(like that name),do the newer clear housing have the same adjustment? Mine are pointed at the ground,maybe in the daylight(it's night in NY),I'll take a look,but if you know,please advise......Thanks
Old Aug 26, 2004 | 09:25 PM
tj99e320's Avatar
Headlight Assy.
Sorry, I wouldn't know . Mine is just like the picture in my previous post.
TJ
Old Aug 26, 2004 | 09:37 PM
raymond g-'s Avatar
99 E320
The Euro clears from Autodynamic have similar horiz/vert adjustment knobs. What it lacks, vs OEM, is the window/bubble level gauge. The adj knobs are in the same location as factory issued headlight units.
Old Aug 26, 2004 | 11:53 PM
ruffrob's Avatar
Thanks ,Ray....
Old May 1, 2006 | 10:58 PM
01BlackE320's Avatar
01 E320
I have this same problem. Left adjuster works, right doesn't. Don't plan on replacing the light assembly. Anyone figure out how to correct this or to adjust the beam another way. I plan on taking it apart but clues would be helpful.
I'm afraid some oncoming driver will shoot me for blinding him with my poorly adjusted headlight
Thanks,
TJ
Old May 2, 2006 | 09:06 PM
cragigotgame's Avatar
97 E420 90 300E
When I bought my xenons a few years ago the adjuster was messed up on mine too. What usually happens is the light is adjusted too high/low and the pieces slip out. Its hard to explain but once you take of the back and you look in there you can see how it works. What you are looking for sits right in between the low beam and the high beam/city light. The adjuster runs vertical and connects to the lens on the top and bottom. There is a little ball on the end of the adjuster that pops into the white tabs on the lens. Youll need to get some big 90Degree pliers to pop it back in. Hope that helps. Should only take about 5 min once you get the headlight assy. out.
