Issue with a E430! Need Help
Old Aug 19, 2007 | 12:27 PM
mario19's Avatar
Hello guys,
I really need some help, while I was in red light waiting the car shut off without any warning. I tried to turn it on again, but no chance. Than somehow after a while the car turned on, I drove for like 10 min to make it home, and again the car shut off, after that the "check engine" light came on. I tried with a jumper to start it, but it didn't seem as a battery problem, the car didnt start again, after trying a trying so many time I managed to drive the car home obviously speeding avoiding to stop on a red light. The next morning when I tried to turn the car on, the car started and the check engine light was off, but the RPM while on "P" gear is very high, it starts from 10 Rpm than it goes to 15 rpm. Some lady on the phone from MB Road Assistance told me could be a "Alternator" or a "Transmission" problem.
Anybody had the same problem? Also I forgot the car vibrates a bit while on "P" gear, I think it vibrated a bit even before this happened.
Thanx
btw this car is a 2001 E430 4 Matic 41k miles
Old Aug 19, 2007 | 08:40 PM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
Originally Posted by mario19
Hello guys,
Thanx
Look like either your MAF or CPS sensor is out of shape
Old Aug 19, 2007 | 08:58 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
+1 MAF and or CPS, many great post on replacing both do a search.
Old Aug 19, 2007 | 10:46 PM
ohlord's Avatar
The light is out
but the code is stored,if the fault is still present.So get the code read,at autozone for free.Maf bad car will run not stall out and die.Most likely the other option above crank position sensor.It measures crank speed to tell the ecu how to fire the ignition.bad no go,failing go,no go,etc.,get the codes resd first so we can see them when you post.......No sense replaceing the cps although pretty cheap and easy to do,without knowing if that is what is indicated.
ohlord
"GOT CODES?"
