check engine electronics due to K&N Air Filter?
Old Oct 23, 2002 | 11:14 PM
cabby850's Avatar
HI,
Does anyone have experience with check engine electronics light appearing after you put in a K&N air filter?
I have a 97 E420 and I just installed a K&N air filter. when I drive the car next day, my check engine light came on. I searched the forum about this and most said its either gas cap open, bad O2 sensor or bad air mass filter.
I am wondering the reason for my check engine light came on after I installed the K&N air filter is because the air mass filter detected additional air intake due to the K&N air filter and therefore think its abnormal. Does anyone else have this problem? Is there a solution to this? Is there anyone using K&N air filter and is just driving with the check engine light on?
Edward
Old Oct 23, 2002 | 11:15 PM
awiner's Avatar
2003 CL55 AMG
It's possible that the K&N's threw some of the oil off of them and it shorted out the MAF sensor. I have heard of this happining, however, not with new K&N's. Usually happens when people over oil them at maintenance.
Old Oct 24, 2002 | 01:26 AM
E420SportGT's Avatar
'97 MB E420 Sport/'88 MR2
You might want to try and disconnect the battery, leave it disconnected for about and hour, and then reconnect it. Maybe the computer will relearn itself with the new K&N filter. Doesn't hurt to try...
Old Oct 24, 2002 | 12:15 PM
6.3's Avatar
6.3
2003 s500 sport
Besides the error did you notice any performance gain?
I am looking into getting it for my e430.
Old Oct 24, 2002 | 03:04 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Post
Remove the Mass air sensor and clean it with a Can of brake clean
Please read the Instructions on the Cleaning the K and N Filter
Do Not Over OIL it as it will kick on the check engine lite and ruin the mass air sensor!
If the Check engine lite came on Yes check the gas cap,
If not take the car to the dealer to sort the problem out!
I Would Install the STOCK AIR FILTER If you take it in for warranty repairs so they cant blame it on a OVER OILED K/N Just My.02
And If you tossed the old filter go buy one its a LOT less than paying for a Mass air sensor!
BTW If you live in So cal I Can recommend a friend!That works at a Dealer
Old Mar 25, 2004 | 12:08 AM
Big Terry's Avatar
2001 CLK 430 Silver
I am also interested if you noticed a big change in performance, I have a Clk 430 and thinking about adding K/N
Old Mar 25, 2004 | 07:49 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
K&N ruining sensors
This typically starts a lot of arguments. BTW George has an Oil testing Co, and is a technical director at MB Club of America
http://mbca.cartama.net/showthread.php?threadid=2198
Old Mar 25, 2004 | 08:04 AM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Im running the K&N and I did notice a little more responsive throttle feel.Also noticed mileage drop,about 3/4 of a mile per gallon.
Old Mar 25, 2004 | 08:31 AM
Whitey's Avatar
98 W210 Advantgarde
Improved mileage and response noted too. Noticeable but can't say its a "big" change, as one would expect
As already said, I believe it is just the over oiling that is the culprit in used filters. Had mine maintained by the mechanic and no problems when I had my K&N installed.......no problems after two years either.
Old Mar 26, 2004 | 01:37 PM
E43's Avatar
E43
2000 E430 Sport
I noticed a minimal performance gain by installing a K&N, although I expected more. I've had no problems since I installed it over a year ago.
On a separate note, does anyone have any experience with aftermarket air boxes such as the RennTech?
