Tires Rubbing
Old Aug 30, 2007 | 04:24 PM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
Question Tires Rubbing
I recently put on AMG E55 stock staggered wheel set up on my 01 E430 and have started experiencing tire rubbing on uneven roads.
Front Tire is 245-40-18 and Rear tire is 275-35-18.
My question is - Will the rubbing soon ruin the tires ? I can live the noise here and there but if it will end up running the tires - Do I need to get the fenders rolled??
Old Aug 30, 2007 | 06:49 PM
43fatman's Avatar
2001 E430 Sport
Where are you experiencing the rubbing?
Old Aug 30, 2007 | 07:19 PM
Britrover's Avatar
It is the front tires that are rubbing when full compression is encountered, eg strong dip in road, or high speed.
Old Aug 30, 2007 | 08:05 PM
43fatman's Avatar
2001 E430 Sport
On the front fender ok what brand tire are you running?
Old Aug 30, 2007 | 11:01 PM
armanchosbenz's Avatar
06 e350 4matic/2000 e320 4matic wagon
The overall diameter of the 245-40-18's is 25'7...your cars
recomended diameter is 25'3...so your front tires are 4/10 of an inch
larger....plus the offset on the front rims is +31...that puts the tire
almost flush with the inside of the fender well....if you want to correct
the problem you need to change to a 235/40/18...the overall diameter
is 25'3...whitch is factory spec....plus this will correct your odometer
reading...i would stay with the 275/35/18's in the rear
Old Aug 31, 2007 | 12:44 PM
Britrover's Avatar
Will rolling the front fenders help fit the 245 size tire ??
If not I will simply wait until the front tires wear out and then I can swap them out for the 235 size Michelin.
I didn't know the E55 had a wider open area for the front tire/wheel.
Old Aug 31, 2007 | 09:12 PM
Will rolling the front fenders help fir the 245 size tire ?? If not I will simply wait until the front tires wear out and then I can swap them out for the 235 size Michelin.
rolling the fenders will probably help,but would you trust someone
to do it,i wouldn't
The e55 front end geometry is different than stock 210's,its designed
to take that perticular wheel setup
Question;...does the car track to the left or right when you encounter
grooves on the road
Old Sep 1, 2007 | 08:40 PM
mbnz320's Avatar
2000 e320
thats is the exact tire size for the E55 AMG i just check the manual. so its a size bigger than our non amg wheels.
