Squeaky Noise due to window tint?
1998 E320
Hi,
I have a '98 E320 that has all four windows tinted. The driver and passenger side windows generally make a squeaky noise when coming down or going up. It sounds like it's being caused by the pressure that the outside rubber is putting on the tinted glass, which in a way is good because that will prevent any leaks. The noise is nothing new; it's just that I finally decided that I would do something about it So, can I do something (wax or some other magic chemical) to either prevent or reduce this noise? I have also noticed that this noise becomes greater during the winter or when it's cold outside, which further confirms my conclusion of the rubber being the culprit.
Thanks!
Thanks!
'97 E320
Hi,
Thanks!
Thanks!
