2000 E320 wagon SRS light, help
Old Sep 8, 2007 | 06:49 PM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
hi all,
"our worn pads" light just went on last week, but today i just noticed that the RED "SRS" light has been intermittently turning on and off...not flickering, but rather it'll go on for 1 minute and then stay off for 5 to 10 minutes, etc...
are these two possibly related? isn't SRS the airbags related?
what could this be...i hope it's not expensive.
Old Sep 8, 2007 | 11:27 PM
1999E320's Avatar
99E320
sounds like it could be a seat belt sensor going bad. try cleaning the the buckle side and see if that helps. some compress air usually works petty good.
Old Sep 9, 2007 | 07:48 AM
chuckmcdonald's Avatar
2000 E430 Sport
My SRS light did the same thing. It was a sensor in the front passenger seat that went bad.
Old Sep 9, 2007 | 10:03 AM
bzliteyear's Avatar
how much is the front seat sensor if that's the problem?
and is that a dealer job, or can indep do that also?
thx for feedback.
Old Sep 10, 2007 | 02:21 PM
01BlackE320's Avatar
01 E320
does it go on/off when you have a passenger? The seat sensor is a common problem. It's unfurtunate because it's a useless feature that is over-engineered and impossible to by-pass without replacement
https://mbworld.org/forums/showthrea...41#post1776641
Old Sep 10, 2007 | 10:29 PM
bzliteyear's Avatar
thx for reply.
the SRS was flashing but is now pretty much always on, regardless of whether there's a passenger or not.
this is mainly our nanny's driver w/ 2 kids in backseat, but i'm curious if the airbag will still work and it's just the light that's on? or is this a problem that might affect deployment and therefore i should fix asap?
thx.
