Getting my 320 lowered Friday- question
Old Sep 11, 2007 | 10:59 PM
Bossman123's Avatar
2001 e320 2004 e55
I am going with the eibach springs for a 1.3 inch drop. My concern is that I don't want the rear of the car to sit lower than the front. If I use #1 pads in the front, will that drop the wheels into the wells? Don't want that either. I think the car comes with 3's all around. If I use those will the front sit higher?
Old Sep 12, 2007 | 12:10 AM
raymond g-'s Avatar
99 E320
presuming that your car came with #3 all around and you keep #3 in rear and
#1 in front.....with the Eibach springs....should result in a slight forward rake.
in the end, it's a bit of a challenge to predict the exact wheel/tire gap....the
exact height until after your car settles in. why? because the other factors
which contribute to ride height, gap, etc are sway bar, shocks, spring rate,
tire profile etc. with all those factors intermixed, it's just a bit of a guess.
a critical eye will discern something as fine as .25" gap diff so in some cases,
selecting the spring pad beforehand is a crap shoot...and is the final adjustment
made after initial installation. spring pads for 210 are in 4mm increments.
Front
210 321 01 84 5mm
210 321 02 84 9mm
210 321 03 84 13 mm
210 321 04 84 17 mm
210 321 05 84 21 mm
rear
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
here is earlier thread...which may help give you an idea what considerations
are involved.
p.s. fronts are traditionally higher than the rear, ie more wheel gap
Old Sep 12, 2007 | 12:14 AM
SpaceCity E 430's Avatar
2011 E350 Sport/ 2000 E430
I ended up up re-shimming all four corners after the springs took a set to get the fender gaps where I wanted them.
Old Sep 13, 2007 | 08:38 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
fendergap FTMFL
