turning off ASR/ESP
Old Sep 16, 2007 | 11:36 AM
jamie645's Avatar
e320 4matic wagon
turning off ASR/ESP
Is there any way to turn off the stability system fully?
I know that on some BMWs if you hold the esp button for like 20 seconds it will turn it off.
Old Sep 16, 2007 | 12:17 PM
ohlord's Avatar
Turn
off the switch on the console,and no you wont be able to burn rubber or hang the tail out around a turn!!!!!!!!!!!!!
"GOT CODES?"
or unplug it under the hood
Old Sep 16, 2007 | 11:22 PM
azurE430's Avatar
1998 E430
why not?....my car does ....if I turn that switch off a yellow light comes on the dash and has full trac-lock....is that not normal?....dry or wet surface.
Old Sep 16, 2007 | 11:40 PM
ohlord's Avatar
you have the v8
his is the 320,laid back,not much of a tire smoker.
and asr/esp has nothing to do with trac lock.
Old Sep 17, 2007 | 02:08 PM
uberwgn's Avatar
e300d
the dash mounted switch only partially shuts down the system. There's a major connector (I don't know which one) under the hood that can be disconnected. That's supposed to completely disable the system.
I'm going to attempt to dyno my car again next month. I'll try to find the answer to this.
