Need Help Asap!!! Removal of Rear Parcel shelf...
Old Sep 22, 2007 | 06:38 AM
ashran2's Avatar
W210 2002
My rear speakers have died and i want to see what the problem is.
The dealer says that it might be due to the loose wiring the car audio shop says that the speakers are dead i have to change them, they did not check the speakers. I really like the sound from the OEM speakers thats why i am wondering how can i see where the fault is, i am guessing the only way to check the speakers is by removing the rear parcel shelf.
Ps: i have searched the forums and i couldn't find any DIY for removal of rear parcel shelf, any help will be greatly appreciated.
Thank you in advance!
Old Sep 22, 2007 | 12:42 PM
ohlord's Avatar
Go down to
the audio section below,several peeps have posted how to's on getting to the speakers..cant you run a test lead to the speakers from under the shelf in the trunk?
https://mbworld.org/forums/sho...ght=rear+shelf
Old Sep 22, 2007 | 01:33 PM
E-Klasse's Avatar
W205 C300
You should be able to get to them from inside the trunk to test them. You might have lost your amp. I don't think both speakers would just go bad. You have to remove the rear seat back to get the hat shelf out.
Old Sep 22, 2007 | 01:39 PM
ashran2's Avatar
W210 2002
Thank You, very much for your help i will try it first thing in the morning, and post whether i have been successful or not.
