Spark Plug Change
Old Oct 4, 2007 | 11:08 AM
Cocca's Avatar
2019 Land Rover Discovery 2018 BMW 540ix 2013 Land Rover LR4 2007 Porsche Carrera 4S Cabriolet
Spark Plug Change
I was told by my dealer that I need new spark plugs. They want to charge me $475 to do that.
I would rather not pay that, but I might be inclined to change them myself if it's "do-able".
I ran a search and came up empty.
So, can anyone point to a thread here or give me some insight on how to do this for my 2002 E430. Are there any tricks? Special Tools? Is it not possible for a do-it-yourselfer?
Thanks.
Old Oct 4, 2007 | 11:20 AM
Quadcammer's Avatar
96 and 08 911 turbos
very possible and not terribly difficult.
The only special tool you may need is the coil near plug wire removal wrench. This is designed to pull the wire off the plug without damaging it.
After that, its a standard plug change, just with 2 plugs per cylinder.
Pop the hood in the vertical position, move the air intake tube and it shoudl be simple.
Old Oct 4, 2007 | 11:55 AM
ohlord's Avatar
Plugs
DIY pretty self explanatory over on benzworld diy section
http://www.benzworld.org/forums/w210...9-27-07-a.html
if you get stumped pm me and I can give you additional tips.Plugs 2.79 ea*16= $44.64 , a torx bit whole set 7 bucks,17mm offset wrench or you can use a long 5/8 open end wrench,a screw driver, torque wrench,and the correct plug socket.all less then 75 bucks,even less if you have the tools or can borrow them.that and about a sat morning,and you are done.
ohlord
"GOT CODES?"
Old Oct 4, 2007 | 02:56 PM
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
ohlord
"GOT CODES?"
+1, I learned the hard way by buying those "rebrand" NGK/MB spark plugs at $25 each Seriously, save yourself money and go to autozone/advance auto and get them..They are identical and only cost $8-9 each. I can't comment on changing the plugs though...
Old Oct 4, 2007 | 10:07 PM
azurE430's Avatar
1998 E430
yeah got it!.........like five times.....hey what about the bosch 4s?.....how many miles are they good for? how do they compare to the factory plugs?
Old Oct 4, 2007 | 11:06 PM
ohlord's Avatar
just buy
the oem style plugs,single side electrode,platinum like the bosch or the ngk,they are 2.79 -2.99 or so.No need for bosch 4,3,2,anything else.Oem go 100,000 miles with hardly any discernible wear,so why spend more for no improvment.
Old Oct 5, 2007 | 12:05 AM
azurE430's Avatar
1998 E430
oem are 8 bucks a piece. and that's getting them online at a deal. dealer wants 12 a piece and I'm not putting ngk in it. are the 430 plugs different than the 320s?. factory ones are double platnum. not cheap. the reason I asked about the bosch 4s is because I got them for 5 a piece. double platnum also. I'm not putting dumpy plugs in this car. its in mint condition
Old Oct 5, 2007 | 05:29 AM
ohlord's Avatar
Here we go again
oem plugs for your "mint"condition 1998 E430 were the same for every112/113 engine
oem was f8dpp332 superseded by fr8dpp33 both were single side electrode platinum plugs.the modern day replacement for this plug is the bosch platinum plus single side electrode plug,not bosch platinum 2 with two side electrodes or bp4 with 4 side electrodes.platinum plus were on sale for 2.99 ea. a few months ago at schucks/kraggens.
BKR5EGP/7090 in ngk also installed as a replacement to the original bosch platin plugs as they called them before the conversion to the newer models.the Bosch platinum plus and the NGK are the closest modern day replacements to the oem plug that were installed in these cars.Shop around I have found them for as low as $2.47 ea and bosch has a mail in coupon good for $1 off each on the platinum plus plug.
http://www.boschautoparts.com/NR/rdo...arktacular.pdf
Or maybe if you put in the more expensive 2 or 4 or 6 sided electrode plugs, you too will have a (mint) condition 10 year old used Mercedes like you know who! btw NGK is the worlds largest supplier of manf oem plugs,you may consider them dumpy plugs that you would not install in your (mint)E430
you would be wrong of course since bosch and ngk are the choice of car builders world wide.
And to think---I told you where to get an obd2 code scanner for $39 and now you bite the hand that feeds you.
ohlord
"GOT CODES?"
Old Oct 5, 2007 | 06:54 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
I did a write up a while back, I have a 1998 C43 with a 113 engine. The most helpful tool are these locking socket extensions they sell at Home Depot) I'm a Craftsman, Snap-On nut but they did not have). I would replace the wires at this time as well. Autohausaz.com had mine for $183 (free ship) I went with the Iridium plugs check out the post #8 --> LINK
Old Oct 5, 2007 | 10:32 AM
ohlord's Avatar
nice
write up,you dont need anything more then the 17mm or the long 5/8 and a short ext variety on the w210 series,and you most assuredly do not need anti seize on the plugs,they are factory plated with an anti corrosion metal.Anti seize only makes the torque setting be off by about 30% and if gotten on the plugs electrode can cause it to arc out and you have a dead plug.Not needed
and no need to replace the wires either if you do the job the way it is done correctly no wires get removed except at the plug ,no wires get damaged,and no wires get displaced.No damage means these wire sets if not abused will last for a good 150000 to 200000 or more miles.no need to throw away good wires,check the resistance,on an old set if you want to prove it yourself.
Old Oct 5, 2007 | 11:43 AM
Untertürkheim's Avatar
I have Bosch Iridium+4 plugs in every gasoline powered car (MB) I drive. I have been extermely happy with them.
Old Oct 5, 2007 | 02:09 PM
Cocca's Avatar
much thanks
as always, thank you all for your assistance.
i will check the DIY section next time first (hadn't occurred to me to check-believe THAT or not!!!!!).
Old Oct 5, 2007 | 02:58 PM
ohlord's Avatar
The diy
section on benzworld.org w210 forum
