Stock Alternator Power OUtput,
thanks
Is the alpine 1 channel?at 1000 watts,have you matched the speakers ohm rating to the amp?Seems at normal draw your 115 amp alt should be able to drive them and not dim the lights.Are you running all the speakers off one amp?
C'MON GUYS HELP ME HERE! lol
Ohlord i really appreicate the reply thanks!
http://decware.com/
he is the guru of car audio.
that little deathbox with one 10in custom speaker is killer.
ohlord
I ask about the fuse in case you did not read the story about the member who had a tire changed and the guy crimped his amp wire,started the car not knowing the wire was bad.shorted out burned up inside the harness all the way under the carpet and fried the harness under the dash
Big wire,proper rated fuse.
tip of the day
