Changing Cabin Air Filter '97 E300... Change radio to IMPROVE sound
On another note. I recieved the radio harness adaptor from Becker and installed my higher model Pioneer radio, and the difference in sound with just the radio alone is astounding. Everything sounds that much cleaner and louder. If you want to be **** you can use the RCA outputs and hook them up to the speakers leads, but thats overkill. Advantage, you can turn your radio up a lot louder at a higher volume value. For the audiophiles :-)
For act. carbon remove plastic panel under dash starting with louver on side of trans hump. Once off you'll see filter chambers.
For both cabin filters and act. carbon filters there are two elements. In the cabin filters there is one opening so remove first one and then slide over and remove second.
For the activated carbon filters there are two chambers. Note filters are slightly different shape so match to one removed.
Good luck.
The cabin dust filters should be changed once a year though, because they do get clogged with dirt and will reduce the efficiency of the climate control system.
Fred
