1999 Mercedes E320 Timing belt
1999 Mercedes E320
Hello ,
I recently bought a 1999 Mercedes E320 . It has now 85000 miles.
1) I would like to know when i should change the timing belt
2) When i should change the serpentine belt
Please let me know. Thanks in advance.
Inspect the serp belt
it may or should have been done at one of the scheduled maint intervals if the po had the car serviced properly.
The w210 has a timing chain and if the correct oil and intervals have been followed,the oil lube on the chain will keep it in nice shape for over 150,000 miles.You are coming up on the 100,000 mile plug change,easy diy and at 85000 miles it is time to change the trans fluid and filter mb fluid only.DIY on
http://www.mercedesshop.com/Wikka/Trans7226Fluid
1999 you have a drain for the converter so all the fluid can be drained out and replaced.
Invest in the 94169 code scanner at harborfreighttools or at one of their stores if you have one nearby it is only 39 bucks online and the store will meet its internet price if you ask.The scanner will read your codes and clear them,plus read I/M readiness for smog tests and is worth its weight in gold if it saves you one trip to the shop to find out why the check engine light is on.
Last but not least,always post a concern or problem here before running off to the dealer or shop,almost anything you encounter has been dealt with,seen,fixed,or solved,so check here first before the shop gets you.
DIY's on http://www.benzworld.org/forums/w210-e-class/ w210 section
suppliers
http://www.autohausaz.com/search/mod...00016&year=All
www.germanstar.net
www.mercedesshop.com (trans, supplies, special dip stick, cap, and fluid)
http://www.danielsternlighting.com/t...lbs/bulbs.html (65watt rally bulbs,bright side marker bulbs,euro spec selective yellow H1 fog bulbs)
ohlord
suppliers
www.germanstar.net
ohlord
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
1999 Mercedes E320
Thanks for your reply
Hello ohlord , Thanks for your reply. I read about the dealers , service sections and all and it was very helpful. I will defenitely post in this forum before going ahead to the dealer. Thanks again
