W210: E320 Wagon - Coolant Temp Sensor
Old Nov 19, 2007 | 08:18 PM
LIME's Avatar
2001 E320 Wagon
I've ordered a new coolant temp sensor for my 2001 E320 Wagon. Where is this sensor located on the engine. A diagram, good explanation, or picture would be much appreciated.
Thank you
Old Dec 2, 2007 | 01:20 AM
SpaceCity E 430's Avatar
2011 E350 Sport/ 2000 E430
Bump. I'd like to know too. It's on my list of things to replace soon.
Thanks.
Old Dec 2, 2007 | 05:44 PM
LIME's Avatar
2001 E320 Wagon
Sensor Location
It is located at the top/front of the engine. If you pop off the plastic engine cover, you will see it at the top/front of engine just left of center. If you have trouble spotting it, let me know. I can post a picture.
BTW, the reason I changed mine was to help solve a stalling problem when engaging the transmission when the engine is cold. Unfortunately, the new sensor did not help.
Old Dec 2, 2007 | 05:53 PM
ohlord's Avatar
If it was bad
you would have had a cel on and a code.Did you?
Old Dec 2, 2007 | 05:57 PM
ohlord's Avatar
Check all
your vacuum lines to the intake.You can test a coolant temp sensor instead of installing a new one just to see if it cures a problem.
vac lines
cam position sensor
egr tube needs cleaning
some other likely suspects
